Hi.
I’m confused! I’ve just installed Home Assistant on my Synology NAS in Docker as per Alternative - Home Assistant, following the Synology NAS section.
Toward the end, this advises “To use a Z-Wave USB stick … See this page for configuring Terminal access to your Synology NAS”, then use SSH to set 2 parameters, and etc…
Then there’s a Note “If you want to use a USB Bluetooth adapter or Z-Wave USB Stick with Home Assistant on Synology Docker these instructions do not correctly configure the container to access the USB devices. To configure these devices on your Synology Docker Home Assistant you can follow the instructions provided here by Phil Hawthorne.” which seem to be for DSM 5 and 6, NOT DSM 7.x. That immediately suggests the above official instructions are very outdated (~5 years old)!
Then again there are multiple topics on the Community forum that seem to suggest very different procedures to setup Z-Wave and connect the USB stick to HA, some a bit old, others 2021’ish.
Some/all? of these guidelines might be outdated as Synology is now on DSM 7.1 and HA keeps improving.
So please will someone point me to the best current setup procedure for
a) Getting HA to use Z-Wave. E.g. do I need to install zwavejs2mqtt in another Docker container, or what?
b) Linking it reliably to a Aeotec Z-Wave Gen5 USB stick on Synology NAS with HA in a Docker container?
Or do Z-wave and USB sticks just not work RELIABLY under Synology DSM 7.x and HA on Docker?
I see a lot of posts saying DSM updates gave Z-Wave USB stick problems.
Many thanks, Ian
