Where is the button to cancel the thing? Backups keep getting created every day and they eat up all my drive space. I have manual backups (well they’re automatic really), and they’re configured the way I want them to. Why is there no button to stop automatic daily backups?
The kind translation: “Help!”
Try going to Settings, System, Backup, Configuration.
On a fresh install, that option does not exist (as it did not on my main HA before going through the “Set up backups” flow.:
I remember pressing “Set up backups” once, as soon as the feature was released, but I never continued the process, I just pressed X when I was presented with the encryption key. Which for some reason proceeded to make automatic backups even though nothing was configured.
You can disable encryption
@TurfFiber: Did you find the solution to this as I’m having the same issue?
Well
Set it up and set it to “Never” as @francisp described
you gotta configure it a bit more, perhaps create a schedule, then you’ll get a button that lets you cancel it all.
