You cannot put an !input parameter inside a template in a blueprint definition. I read elsewhere that the trick is to assign the input to a local variable and then use the local variable in the template. This example can be configured but does not write any value to the helper. What is wrong with it?
input:
event_description:
name: Event description
description: The global variable (helper) to hold the description of the current event (if any)
selector:
entity:
domain: input_text
event_temperature:
name: Event temperature
description: The global variable (helper) to hold the temperature specified in the current event (if any)
selector:
entity:
domain: input_number
variables:
local_event_description: !input event_description
- service: input_number.set_value
value: >-
{% set temperature_text = states('local_event_description').split('#')[1] %}
{{ '%0.1f' | format(float(temperature_text)) }}
entity_id: !input event_temperature
The template was originally tested in an automation (where no local variable is needed), but failed when transferring it to a blueprint.
Does it have to do with the scope of the local variable? It is defined at the outer level of the blueprint as I could not get it accepted closer to the template.
I am not even sure how to debug this; how do I see inside local variables and templates?
Here is the full blueprint definition code at the present state of testing
### ANDY'S RADIATOR CONTROLLER
### Andy Symons 31-Jan-23
### Controls radiator temperature from a calendar,
### allows temporary manual override,
### and turns off radiator if a door or window is opened,
### or if the room is unoccupied for a while
blueprint:
name: Andys Radiator Controller
description: Controls radiator temperature from a calendar, allows temporary manual override, and turns off radiator if a door or window is opened or if the room is unoccupied for a while
domain: automation
### INPUTS
input:
radiator_thermostat:
name: Radiator thermostat
description: The device that controls the radiator TRV
selector:
entity:
domain: climate
radiator_set_temperature_sensor:
name: Radiator thermostat set temperature
description: A (template) sensor that reads the set temperature from the radiator thermostat
selector:
entity:
domain: sensor
radiator_calendar:
description: The calendar dedicated to scheduling events for this radiator
selector:
entity:
domain: calendar
door_or_window_opening_sensor:
name: Door or window opening sensor
description: The sensor [group] that detects whether any external door or window is open
selector:
entity:
domain: binary_sensor
device_class: opening
door_or_window_open_recognition_time:
name: Door or window open recognition time
description: The time for which a door or window can be open before the heating switches off
selector:
time:
default: "00:03:00"
door_or_window_closed_recognition_time:
name: Door or window closed recognition time
description: The time for which a door or window has to be closed before the fact is used
selector:
time:
default: "00:03:00"
room_occupancy_sensor:
name: Room occupancy sensor
description: The sensor [group] that detects whether there is anyone in the room
selector:
entity:
device_class: occupancy
room_occupancy_recognition_time:
name: Room occupancy recognition time
description: The time for which the room has to be unoccupied before the fact is used
selector:
time:
default: "00:00:10"
room_unoccupancy_recognition_time:
name: Room unoccupancy recognition time
description: The time for which the room can be unoccupied before the heating switches off (except suring the warm-up period)
selector:
time:
default: "01:00:00"
warmup_timer:
description: The global variable (helper) to hold the timer for the event warmup period
selector:
entity:
domain: timer
warmup_period:
description: The period of time from the start of a new event for which room unoccupancy will be ignored
selector:
time:
default: "02:00:00"
event_name:
description: The global variable (helper) to hold the name (aka Summary) of the current event (if any)
selector:
entity:
domain: input_text
event_description:
selector:
entity:
domain: input_text
event_start:
description: The global variable (helper) to hold the start date and time of the current event (if any)
selector:
entity:
domain: input_datetime
event_end:
description: The global variable (helper) to hold the end date and time of the current event (if any)
selector:
entity:
event_end_offset_time:
name: Event end recognition time
description: The time for which acting on an event end is deferred in order to detect a contiguous event
selector:
time:
default: "00:01:00"
event_temperature:
selector:
entity:
manual_temperature:
name: Manual temperature
description: The global variable (helper) to hold the temperature specified by manual control of the device or the dashboard
selector:
entity:
manual_mode_recognition_period:
name: Manual mode recognition time
description: The time period for which a manual setting has to be stable before it is taken as a new manual setting
selector:
time:
default: "00:00:03"
manual_override_timer:
name: Manual override timer
description: The global variable (helper) to hold the timer for a manual intervention
selector:
entity:
domain: timer
manual_override_period:
name: Manual override period
description: The time period for which a manual intervention will override the schedule
selector:
time:
default: "01:00:00"
setting_reason:
description: The global variable (helper) into which the automation writes the reason for the current setting (for use on a dashboard)
selector:
entity:
domain: input_text
echoblock_timer:
description: The timer for use inside the automation to disinguish genuine manual changes of the set temperature from those set by the automation
selector:
entity:
domain: timer
echoblock_period:
description: The time period for which am echo may be received from the automation setting the thermostat
selector:
time:
default: "00:00:10"
mode: single
## LOCAL VARİABLES
## needed to capture global varable values for use in templates
variables:
local_event_name: !input event_name
local_radiator_set_temperature: !input radiator_set_temperature_sensor
## TRIGGERS
# 1. Calendar event start
- platform: calendar
event: start
entity_id: !input radiator_calendar
# 2. Calendar state to on
# (Similar to event start but can be around 30 seconds later)
- platform: state
to: "on"
# 3. Calendar event end
event: end
offset: !input event_end_offset_time
# 4. Calendar state from on to off
# (Similar to event end but can be around 30 seconds later)
- platform: state
to: "off"
# 5. Change in the thermostat set temperature
# (could be manual override but could also be an echo at this stage)
- platform: state
entity_id: !input radiator_set_temperature_sensor
#for: !input manual_mode_recognition_period
# 6. End of manual override
- platform: state
entity_id: !input manual_override_timer
to: idle
# 7. Room becomes unoccupied
- type: not_occupied
platform: device
device_id: 737e8f81fcac51fcdcdce5629ff6cb1a
entity_id: !input room_occupancy_sensor
#for: !input room_unoccupancy_recognition_time
# 8. Room becomes occupied
- type: occupied
platform: device
#for: "00:00:00" #!input room_occupancy_recognition_time
# 9. A door or window is opened
- type: opened
platform: device
device_id: 4b75acd529cf91315e5fe62a43a1a2b3
entity_id: !input door_or_window_opening_sensor
#for: !input door_or_window_open_recognition_time
# 10. All doors and windows closed
- type: not_opened
platform: device
#for: "00:00:00" #!input door_or_window_closed_recognition_time
## ACTIONS STEP 1 -- SET THE STATE VARİABLES
- choose:
# a. Calendar event start
- conditions:
- condition: trigger
sequence:
# i. capture the event name, start, end and description
- service: input_text.set_value
value: "{{ trigger.calendar_event.summary }}"
entity_id: !input event_name
- service: input_datetime.set_datetime
datetime: "{{ trigger.calendar_event.start }}"
entity_id: !input event_start
datetime: "{{ trigger.calendar_event.end }}"
entity_id: !input event_end
value: "{{ trigger.calendar_event.description }}"
entity_id: !input event_description
# ii. Extract the temperature from the description (enclosed in hashes) and round to one decimal place
value: >-
# iii. start the warmup period timer
- service: timer.start
duration: !input warmup_period
entity_id: !input warmup_timer
# b. Calendar event end
- conditions:
# Only act if the ending event is the current one; otherwise a consecutive event has already started
- condition: template
value_template: >-
{{ trigger.calendar_event.summary == states('local_event_name') }}
sequence:
# i. Clear the event name
value: (none)
# ii. Clear the event description
value: (none)
# iii. Clear the event temperature
value: 5
# iv. Clear the warmup timer
- service: timer.cancel
data: {}
# c. Manual override start
- conditions:
#ignore if it is just an echo from a setting from this automation
- condition: state
entity_id: !input echoblock_timer
state: idle
sequence:
duration: !input manual_override_period
value: "{{ states('local_radiator_set_temperature') }}"
entity_id: !input manual_temperature
# d. Manual override end
- conditions:
sequence:
value: 5
## ACTIONS STEP 2 -- SET THE TEMPERATURE ON THE THERMOSTAT AND RECORD WHY
- choose:
# 1. If a door or window has been open for the set time, turn the heating off
- conditions:
- condition: state
state: "on"
#for: "00:00:00" #!input door_or_window_open_recognition_time
sequence:
- service: climate.set_temperature
temperature: 5
entity_id: !input radiator_thermostat
value: Turned off because a door or window is open
entity_id: !input setting_reason
# 2. If the room has been unoccupied for the set time, turn the heating off
- conditions:
- condition: state
state: "off"
#for: "00:00:00" #!input room_unoccupancy_recognition_time
# Do not act on unoccupancy during the warmup period
- condition: state
state: idle
sequence:
temperature: 5
value: Turned off because the room is unoccupied
# 3. If there is a manual override in operation
- conditions:
- condition: state
state: active
sequence:
temperature: !input manual_temperature
value: Set manually
# 4. If there is an active calendar event
- conditions:
- condition: state
state: "on"
sequence:
temperature: !input event_temperature
value: Set according to a calendar event
# 5. If there is no active calendar event
- conditions:
- condition: state
state: "off"
sequence:
temperature: 5
value: Turned off because nothing is scheduled
# Default should never happen!
default:
temperature: 5
value: Turned off by default
# Start the echo-block timer
duration: !input echoblock_period
(The For: statements are commented out to circumvent another problem that I raised as a separate post)
