I receive MQTT messages with a specific payload and would like to start different automations depending on a subset of this payload.
The payload is of the form XXXXXXYYYYYY
where
YYYYYY
is the identificator of a switch (this is what I will match in a condition) -
XXXXXX
is unpredictable, changing and will be useful in state updates - it changes at every message (and therefore, when used as a state, changes the state)
In order to use it, I borrowed from @danpow solution and created a sensor in configuration.yaml
which holds that payload:
# sensors to process MQTT messages from RF wall switches (keep the last 6 chars)
# see https://community.home-assistant.io/t/extract-and-match-time-from-mqtt-payload-to-aid-automation/35546/2
- platform: mqtt
state_topic: 'rfbridge-1/rfin'
I expected to use this sensor later in a set of automations, such as
- id: 'wall_switch_ch2_lampe_pixar'
alias: wall switch chambre 2 lampe pixar
initial_state: True
- platform: state
entity_id: sensor.rf433_switch_payload_full
condition:
condition: template
value_template: "{{ state_attr('sensor.rf433_switch_payload_full','state')[-6:] == '5976A1' }}"
entity_id: light.ch1_lampe_bureau
service: homeassistant.toggle
The value-template
line creates all kind of errors when the automation is triggered.
I tried various incantations to retrieve the actual content of the sensor (that is, XXXXXXYYYYYY
in the example above): sensor.rf433_switch_payload_full.state
, state.sensor.rf433_switch_payload_full.state
and others. Blindly, as I cannot peek at the actual object.
How can I access what I see as βStateβ in the entity sensor.rf433_switch_payload_full
