Hello, I have set up home assistant on a Linux VirtualBox on my Windows 10 computer and I am wondering how can I access the configuration.yaml to configure it, and all the other files??
I tried FTP but can’t connect…
I tried with these settings:
By default, the root user on Ubuntu is disabled. You need to SSH in as the user YOU set up during the Ubuntu installation. You will also need to make sure openssh-server is installed, it’s not by default.
It’s HassOS. It’s running the regular Home Assistant OS.
You access the files via the frontend, using the UI Editor, or you enable the Samba addon, or the SSH addon and access them that way. You can also use VSCode + the HA Extension.
You do not “install it to be Ubuntu” because HassOS is its own OS. It shares nothing with Ubuntu but the fact it’s running a linux kernel.
Your config shows that you set up SAMBA, and you’re trying to connect to it using SSH/SFTP. These are completely different protocols. If you want to connect using SSH/SFTP, then you need the SSH add-on.
As it stands right now, you can just connect using your normal Windows file explorer/browser
I feel dumb. hehe. I just ended up using the web file editor. And I’m also following the documentation now. Something I should be doing from the beginning.
