I want access homeassistant from external.
Then, what I have to do?
thanks
thanks
Have you ever set up port forwarding on your router to a device on your network before? The procedure is roughly the same, depending on whether you are running SSL on you HA instance or not.
@fabaff’s pointer would be the place to start.
Here’s a video tutorial on this topic: https://www.youtube.com/watch?v=BIvQ8x_iTNE&list=PLgtGAtCt_hGRfyXZPW0OUMmmUgUskRVrY&index=5
Why take the risk of port forwarding? Just use a VPN, much more secure. A lot of routers support Openvpn or IPsec. I have my phone constantly connected on my VPN. All traffic is going trough this VPN. Also much more secure for unsecure wifi networks (not only for using homeassistant).
thanks everybody.
I solved problem!
Good to hear. It’s always nice to give a short explanation of what you did so that it might help someone down the line.
I sovled by port forwarding.
To tell the truth, I already tried port forwarding before uploading question.
By mistake, I used internal ip.
So then, I thouht the problem is not on the port forwarding.
It is my wrong.
Now, I catch my mistake, and I use ‘external IP’.
Finally I finished external access.
So, I can solve this problem by port forwarding.
Thanks everyone!
And thank you for sharing the solution!
