How to access Home Assistant zigbee2MQTT with web browser
Normally you access the zigbee2MQTT webpage
http://192.168.1.x:8080
Looking at the zigbee2MQTT config for the Add on zigbee2MQTT it looks like it uses 8485
So in theory http://192.168.1.x:8485 should allow me to access in a standalone web browser.
But I get a ‘can’t open page error’ anyone got any ideas?
You can use the Open Web UI button in the addon (or Show in Sidebar and click there)
The frontend port (8099) is disabled by default, but you can enable it in the addon configuration.
PERFECT!!!
Awesome now to figure out how to access Node Red when inside Home Assistant :slight_smile:
That ‘unlocked’ using zigbee2MQTT Proxy as well :slight_smile:
