How to access host raspbian system from within hassio docker container?
i need to access and modify /boot/config.txt (and some other things), but i can only log into the hassio container. How can i do this?
There are a few options, this thread explains them.
finally i generated keys, ssh/connected to port 22222 (as root), find myself in “Hass.io CLI for HassOS”, followed a suggestion “If you need access to host system use ‘login’.”
finally i found myself in a very strange environment… where is /boot/config.txt to specify temperature/gpio configuration???
i found it!!! /mnt/boot/config.txt
thanks man!
Ah good! Glad you figured it out.
