I have found another post mentioning that you can use flux/magic Home to control this.
However, the light doesn’t perform well as you can change the color and brightness, turn it off but then it doesn’t turn on again. While searching how to fix this, i stumbled upon this post mentioning that you need to replace the Lights.py and it should work: Flux Led/MagicLight don't work since few updated - #4 by lockey4
My problem is, how do i access the Lights.py considering that the set up is on Virtual Box?
I installed Samba but this gives access to the supervisor folder and i cannot find the file i am looking for. I also installed Terminal & SSH but didn’t work for me…
Can you maybe help with SAMBA which seems to be working? What is the path to the file please?
Yes i run windows… So with Samba enabled, i type \ipaddress\ in the file explorer and i do get access but only to the following directories:
addons
backup
config
media
share
ssl
Many of them are empty and i cannot find the Lights.py in any of them. Just to also say, the add-on works mentions in the documentation that access is given in the above directories so it works as intented.
That did the trick!!! I created a custom_components folder in the config (which i had access via SAMBA) and placed the following file found on github: https://github.com/CorneliousJD/Flux_LED
Now the light strip in the aquarium stays on and i can control it!
Thank you both for your inputs! One problem less
Kind Regards
M
