Totally newbie here. I have a raspberry pi installed with the home assistant image.
I was able to access the pi via URL: http://homeassistant.local:8123/ in my macOS.
So all the on-boarding has been set up, now comes to customization…
I wanted to do a simple change of changing the component: person.poponuts
icon / avatar / image using the attribute: entity_picture
. However, I am not sure what value / path to enter and how to access that directory. Obviously, I need to add an image like "/local/image.jpg"
Do I need to remove the SD card from the pi then access it via a Windows OS (after flashing the HA image, I am unable to read it from macOS) and place the image in the root directory: hassos-boot
Also, do I manually create a yaml file on that directory?
