I have Home Assistant 0.99.3 using Hassio on a Raspberry Pi 3B+
My AEON Labs ZW090 Z-Stick Gen5 EU, Fibaro Wall plug, Neo Coolcam powerplugs work well.
I also have a Aeotec recessed door sensor which I was not able to activate.
So I bougt a NEO Coolcam door/window sensor. I was able to connect it with the result of ‘unknown node 7’ and ‘query stage Probe’
The state of the door sensor is ‘initializing’ instead of ‘ready’ the state of my powerplugs.
node id 7
node name Unknown Node 7
manufacturer name
product name
query stage Probe
is awake false
is ready false
is failed false
is info received false
max baud rate 40000
is zwave plus false
capabilities beaming, routing
sentCnt 1
sentFailed 1
retries 0
receivedCnt 0
receivedDups 0
receivedUnsolicited 0
lastRequestRTT 0
averageRequestRTT 0
lastResponseRTT 0
averageResponseRTT0
wake up interval 3600
Also after 12 hours waiting the sensor is not awakening.
What can I do to get it working?
My guess is the sensor is too far away from your hub stick right now and isn’t repeating through other z-wave devices, try to include it closer to your stick, place it in the final location, then heal your network and see if that helps.
Ski522 Thanks for your suggestion.
I placed the sensor directy next of the USB stick… then I opened and closed the sensor.
I tested the network and healed it afterwards:
No succes till so far.
The log states:
2019-09-28 15:18:10.683 Info, Requesting Neighbor Update for node 7
2019-09-28 15:18:10.683 Detail,
2019-09-28 15:18:10.683 Detail, Node007, Queuing (Controller) Request Node Neighbor Update
2019-09-28 15:18:10.683 Detail, Notification: ControllerCommand - Starting
2019-09-28 15:18:10.683 Detail, Notification: ControllerCommand - Sleeping
Hi Philip,
Your suggestion sounds great. I copied the text in the configuration.yaml and renamed the node front_door…
This does not work. Do I have to use the sensor text in an another file?
It’s a pain to include the device but I managed to do it. Complete procedure for the combination NEO Coolcam Door/window sensor and AEOTEC Z-Wave USB stick is:
Reset the device by holding the code button 10 seconds until the led flashes
Set the Z-wave controller in inclusion mode
Fast press the code button 3 times and wait for inclusion to complete
Put the stick back in the Pi and restart HASS (keep the new device within range)
Keep the device awake by repeatedly fast pressing the code button 3 times until the NEO door sensor appears in de devices list. (you can do this with short interval)
At first I only saw three entities but later on after reboot again I also found the battery entity. All works fine now.
