Hello, I installed the pironman 5 software on the Raspberry Pi 5 OS, and the display on the pironman 5 works perfect.
After installing Home Assistent, and rebooting the machine the display doesn’t turn on.
Can somebody tell me how to fix this problem?
Thx.
What Home assistant flavor did you install? HAOS?
I wonder if HA even has drivers to use that display…
EDIT: check this GitHub - sunfounder/home-assistant-addon
You may have better luck trying the route you are taking and good luck but the driver for the hardware display itself doesn’t work under HAOS, but is designed to run on Raspbian and needs to be installed on the host itself. Mine works fine with HA, here is what I did - (HAOS on a VM on the RPI5 with Pironman 5).
