Is there now support for the Tuya Zigbee sensors?
When will the support for the sensors start?
Thanks in advance
LG
Thanks in advance
LG
Pair them with Zigbee2MQTT or ZHA. They work fine in HA with those integrations.
Thank you for your Answer!!
Now i got a Tuya Gateway and Tuya Zigbee Sensors.
Which USB do i have to buy? Can i use a CC2531?
which firmware must be installed on the CC2531? What do I have to watch out for when I buy the USB? Are Zigbee 3 devices all compatible with each other with the stick or is there something I have to watch out for? Is the CC2531 compatible with Zigbee 3
Should i buy this one
or
this one?
thank you so much
The Cc2531 amazon link is a scam. The same device you can buy on ali for 8 β¬ or less. The conbee is a good device. You can also consider buying a sonoff ZbBridge and flash it with Tasmota.
People buy the CC2531 because it it the cheapest way to try out ZigBee, since a preflashed CC2531 stick can be bought from Sonoff for less then 4β¬, but it is only good for small networks or if you have a lot of devices that act as routers.
ok thank you
The device is definitely so cheap on Aliexpress - but itβs also good.
The CC2531 is designed for approx. 30 devices. Which device do I have to use if I want to integrate more Zigbee sensors? How many sensors does the Conbee 2 support and can you also operate Tuya sensors with them?
What do I do if the range of the cc2531 or Conbee is too low. Are there repeaters?
Thanks again you know your way around very well and help me well
Here is a discussion of various adapters :
For Zigbee, in theory any mains powered device can work as a signal repeater. Although you can buy dedicated repeaters ( e.g. the Ikea signal repeater ) or build them yourself ( a CC2531 OR CC2530 flashed with router firmware)
