Hi!
I have tried to make use of mqtt with a sensor that I have made. https://community.home-assistant.io/t/diy-low-powered-esp8266-window-sensor/224687
But I am having trouble getting “things” to work properly, and the sea of old and new information is a bit overwhelming so I wanted to see if anyone could help me understand what is actually needed of configuration in home assistant and the c++ code on the esp8266.
I have installed the add-on Mosquitto broker (version 5.1), and the current config is like this:
mqtt configuration
logins:
- username: mqtt_user
password: mqtt_password
anonymous: true
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
After the installation I added the integration in home assistant and enabled discovery.
The current code I have on the esp8266 is like this, I am using the pubsubclient (version 2.8):
esp8266 code
#include <ESP8266WiFi.h>
//#include <WiFiClient.h>
#include <PubSubClient.h>
#include <secrets.h>
String ssid = SECRET_SSID;
String password = SECRET_PASS;
String hostName = "esp12_mailboxsensor01";
//IPAddress ip(192,168,1,154);
//IPAddress gw(192,168,1,1);
//IPAddress dns(192,168,1,2);
//IPAddress subnet(255,255,255,0);
#define MQTT_SERVER "192.168.1.20"
int sensorPin = 12;
int enablePin = 5;
int sensor;
int code;
String temp = "homeassistant/" + hostName + "/opening";
const char* stateTopic = temp.c_str();
//Enable getvcc
ADC_MODE(ADC_VCC);
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
//Enable power signal as soon as possible
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, HIGH);
pinMode(sensorPin,INPUT);
Serial.begin(115200);
Serial.println();
//Connect to WIFI
WiFi.mode(WIFI_STA);
WiFi.hostname(hostName);
//WiFi.config(ip, subnet, gw, dns);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("WiFi failed, retrying.");
client.setServer(MQTT_SERVER, 1883);
while (!client.connected()) {
// Attempt to connect
if (client.connect(hostName.c_str())) {
Serial.println("connected");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
//Get the battery voltage and send to HA
float vcc = ESP.getVcc();
vcc = vcc / 1000;
String svcc = String(vcc,3);
Serial.println(svcc);
// Serial.println(code);
// Serial.println();
sensor = digitalRead(sensorPin);
//Send new data to HA
if (sensor == 0){
client.publish(stateTopic, "open");
Serial.println("Published open.");
else if (sensor == 1) {
client.publish(stateTopic, "closed");
Serial.println("Published closed.");
//Turn of the latching circuit
digitalWrite(enablePin, LOW);
void loop() {
//Don't want to loop anything
In the logs on the core_mosquitto I get these messages:
1600258898: New connection from 192.168.1.203 on port 1883.
1600258898: New client connected from 192.168.1.203 as esp12_mailboxsensor01 (p2, c1, k15).
1600258920: Client esp12_mailboxsensor01 has exceeded timeout, disconnecting.
And I can’t find any information information in home assistant that it has received anything.
There are neither any devices showing up in the MQTT integration.
Some questions I have that don’t need to be answered if they don’t contribute to the solution.
- I have read on https://www.home-assistant.io/docs/mqtt/discovery/ that it requires configuration written in the yaml file. Is this true when enabling the discovery when enabling the integration?
And if not, what is the discovery_prefix? - The example in https://www.home-assistant.io/docs/mqtt/discovery/#motion-detection-binary-sensor shows that the sensor should be created manually before turning it on, maybe this is what I am missing? If so, how could I write that in the c++ code?
- Is there anything else I am missing?
