How to add a buzzer feature to Home Assistant Yellow?
For a project, I would like to connect a buzzer to Home Assistant Yellow, any idea on how to achieve this?
The project purpose is to build a timetracking tool for a customer’s offices.
Basicly, when employees will reach their office, they will use RFID tag to scan a tag reader (probably the one provided by @adonno), an automation will then send employee_id to an timetracking API that’ll keep record of hours or coming/leaving.
I know the tag reader has already a buzzer, but if buzzer is enabled, from what I know it’ll beep everytime a tag is scanned. What I need is to being able to do a different sound when employee check-in, and another one when he check out. This will depend of the API feedback. It’s why I thought adding a buzzer to make the magic happen.
  • Is it possible to add in the Home Assistant Yellow box a buzzer ?
  • Is there wireless buzzer or ring that can do the job or another idea?
  • Could it be possible that H.A use the buzzer of the tag reader to send back one or two beep?
any ideas are welcomed :wink:
Use Media to play a WAV using the 3.5 mm audio jack.
If you’re using the ESPHome based tag reader, then the firmware for that will be easy to customise for different arrive/leave sounds (I assume it has a passive rtttl buzzer?)
You’d likely have a work/away binary sensor which is toggled by a card swipe (and anything else you want) and have a single beep for work and a double beep for away.
I don’t personally really see the need to get the yellow too involved, I would leave most of the work to the esp and ESPHome.
Good pont - the “standard” ESPhome RFID card reader design from a couple of years ago uses a buzzer which is really a piezo speaker which allows ESPhome to play different tones, and not just beeeeep.
This can be seen in the standard YAML where several different noises are configured:
    - rtttl.play: "success:d=24,o=5,b=100:c,g,b"
    - rtttl.play: "beep:d=8,o=5,b=100:b"
    - rtttl.play: "write:d=24,o=5,b=100:b,b"
Add two switches in ESPhome to play In and Out noises, and trigger from HASS.
Shouldn’t even need to trigger it from Hass if you don’t want.
ESPHome should be able to track and action it all internally and basically be stand-alone without HA being involved much.
You could just have the work/away status sent to HA for reporting, and have a toggle button for HA to remotely override the work/away state if you need that functionality (say you want people to also be able to sign on/off via HA in the browser).
Thanks a lot for your feedbacks !
I get it works as expected. My API send a json feedback that allow me to modulate the sound on the ESPHome Tag reader with RTTTL melodies. I did the automation on H.A side, that was easyer to handle…
alias: Timetracking
description: Gère les scans sur le lecteur dédié au timetracking
  - platform: event
    event_type: tag_scanned
condition:
  - condition: template
    value_template: "{{ trigger.event.data.device_id == '110266286d413c88f8755fbd2xxxxxx' }}"
  - service: input_text.set_value
      entity_id: input_text.tag_id
      value: "{{ trigger.event.data.tag_id }}"
  - service: shell_command.tag_tracking
    data: {}
  - delay: "00:00:02"
  - choose:
      - conditions: "{{ states('sensor.employee_status') == 'checkin' }}"
        sequence:
          - service: esphome.tagreader_0ed2df_play_rtttl
              song_str: welcome:d=4,o=5,b=125:16a#,16c6,16d6,16d#6,2f6
      - conditions: "{{ states('sensor.employee_status') == 'checkout' }}"
        sequence:
              song_str: goodby:d=4,o=5,b=140:8c.,16g4,g.4
      - conditions: "{{ states('sensor.employee_status') == 'error' }}"
        sequence:
              song_str: error:d=24,o=4,b=100:4b,4a,4g#,4g,4b,4a,4g#,4g
mode: single
& in the config file:
shell_command:
  send_tag_id: "curl -o /config/.storage/status.json 'https://mydomain.com/timesheet.php?tag_id={{ states('input_text.tag_id') }}'"
command_line:
  - sensor:
      command: "cat /config/.storage/status.json | jq -r '.status'"
      scan_interval: 1
input_text:
  tag_id:
    initial: ""
