How to add a Garage Door Opener to ZHA?
I’m running HA 2022.8.7.
I’m trying to get a garage door opener to work.
This is the item : https://www.aliexpress.com/item/1005003610757320.html
ZHA has detected it and and it has been added but it doesn’t show and controls to the sensor state.
this is what I see in the device configuration:
Any thoughts or suggestions how to get this working ?
Thank you
Greg
Have you restarted HA yet?
I sometimes need to restart to get some ZHA devices to show up correctly.
The device isn’t supported in ZHA yet.
Looks like it is being worked on here: https://github.com/zigpy/zha-device-handlers/issues/1260
Thanks for that , restart didn’t make any difference for this device.
Yeah, if its not seen report “Device support request” to ZHA Device Handlers (a.k.a. zha-quirks) repo:
Be sure to search there for using the Zigbee device signature to see if there are any existing requests.
Read these ZHA documentation sections relative to understanding why such “quirks” are needed:
https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
https://www.home-assistant.io/integrations/zha#reporting-issues
