Hi all,
Could someone point me in the right direction to add the following feature to this ESPHome device?
The ESP is in deep sleep most of the time. Every 5min it wakes up, connects to WiFi, updates the sensors, and goes back to sleep. Normally, the awake time is around 5-6s.
I’d like to add a sensor “timeawake” to log how long it’s awake every cycle.
So in modified pseudo-code, I want to do this:
esphome:
platform: ESP8266
board: d1_mini
on_boot:
- int t1 = millis(); <============================= TO ADD
- wait_until: mqtt.connected
- component.update: 'esp_am2320'
- component.update: 'abshum_livingroom'
- component.update: 'am2320_rssi'
- delay: 1s
- int t2 = millis(); <============================= TO ADD
- int timeawake = t2 - t1; <============================= TO ADD
- //update a timeawake sensor <============================= TO ADD
- deep_sleep.enter:
Thanks! The full current code is added below.
esphome:
platform: ESP8266
board: d1_mini
on_boot:
- delay: 1s
- deep_sleep.enter:
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: x
gateway: x
subnet: x
dns1: x
fast_connect: true
logger:
mqtt:
broker: x.x.x.x
username: ''x"
password: 'x!'
birth_message:
will_message:
ota:
password: 'xxx'
deep_sleep:
run_duration: 30s
sleep_duration: 5min
# Example configuration entry
i2c:
- platform: am2320
setup_priority: -100
temperature:
name: "Living Room Temperature"
humidity:
name: "Living Room Humidity"
update_interval: never
#filters:
#- sliding_window_moving_average:
#window_size: 15
#send_every: 15
#send_first_at: 1
name: "Living Room Absolute Humidity"
lambda: |-
const float mw = 18.01534; // molar mass of water g/mol
const float r = 8.31447215; // Universal gas constant J/mol/K
return (6.112 * powf(2.718281828, (17.67 * id(temp_livingroom).state) /
(id(temp_livingroom).state + 243.5)) * id(humidity_livingroom).state * mw) /
((273.15 + id(temp_livingroom).state) * r); // in grams/m^3
accuracy_decimals: 2
icon: 'mdi:water'
unit_of_measurement: 'g/m³'
- platform: wifi_signal
name: "AM2320 WiFi Signal"
