How to add a Yes/No/Dismiss in this script
coming from the old actionable notifications with the ios: categories, I am faced with a challenge… I don’t really see where to add the new notification in to this script below. The current script runs fine, has a wait_template to await some user action, and if not, simply continues without action.
I’d like to add the Yes/No/Dismiss option to a question “Do you want to switch off the Netwerk Library anyway?” and if yes, run the script that is listed at the end, ‘script.switch_netwerk_library_off’ . I am completely lost though reading https://companion.home-assistant.io/docs/notifications/actionable-notifications#building-notification-action-scripts which seems to make it so complex… What to add, I dont think I need variables at all?
Please help me out here:
prompt_imac_library:
  alias: Prompt iMac Library
  mode: restart
  sequence:
    - service: notify.system
        title: >
          Rpi4: Network Library can't be powered down
        message: >
          {% if is_state('binary_sensor.imac_library_off','off') %} Switch off iMac Library, might be charging!
          {% elif is_state('sensor.hvb_macbook_pro_primary_display_name','DELL U2720Q') %} Turn off your Dell monitor
          {% else %} Check power usage in the Library
          {% endif %}
  # here for the actionable notification?
    - wait_template: >
        {{is_state('binary_sensor.imac_library_off','on') or
          states('sensor.netwerk_library_actueel')|float < 12}}
      timeout: '00:15:00'
      continue_on_timeout: 'true'
  # or here...?
    - choose:
        conditions: >
          {{is_state('binary_sensor.imac_library_off','on') and
        sequence:
          service: script.turn_on
            entity_id: script.switch_netwerk_library_off
    - condition: state
      entity_id: input_boolean.notify_system
      state: 'on'
        message: >
         {{as_timestamp(now())|timestamp_custom('%X')}}: {{'Switched off iMac library, continuing...'
           if is_state('binary_sensor.imac_library_off','on') else
           'You need to manually turn off iMac library later'}}
Ive added
    - service: notify.mobile_app_calltheboss
        message: Do you want to switch off anyway?
          push:
            badge: 22
          actions:
            - action: "TURNOFF"
              title: "Yes"
              destructive: true
            - action: "LEAVEBE"
              title: "No"
            - action: "DISMISS"
              title: "Dismiss"
to the first position comment, but nothing is happening after the initial notification…
the automation I tried is:
automation:
  - alias: iOS - Network library notification
    id: iOS - Network library notification
      platform: event
      event_type: mobile_app_notification_action
      choose:
        - conditions: >
            {{trigger.event.data.action == 'TURNOFF'}}
          sequence:
            - service: script.turn_on
                push:
                  badge: 0
                title: Netwerk Library
                message: Switched off, badge reset
        - conditions: >
            {{trigger.event.data.action == 'LEAVEBE'}}
          sequence:
              push:
                badge: 1
              message: Ok, leave it be
# case DISMISS
      default:
#          push:
#            badge: 0
#          title: Netwerk Library
          message: clear_badge #Dismissed, badge reset
entering the data of the notify in the service page does connect and display the badge and message on the iPhone…
thanks for having a look!
edit
Ive put the above in a separate script and added that in the prompt_imac_library contain script, and now is works… how’s that for mystery…
edited the automation a bit too:
automation:
      platform: event
      choose:
        - conditions: >
          sequence:
                data:  # <--- needed the double data key
                  push:
                    badge: 0
        - conditions: >
          sequence:
                push:
                  badge: 1
# case SILENT
      default:
