Hello, I am totally new to HASS.
Steps done so far:
- After installation, the cmd command “py -m homeassistant --open-ui” has started successfully the local server.
- In “configuration.yaml”, the only change done was adding a “vera_controller_url:”, which successfully displayed in the HASS UI all the added nodes to the Vera controller.
Now, I would like to be able to trigger node inclusion from the UI. However I don’t know how to run the add_node service. In the UI, when I go to Developer Tools > Services, the “zwave/add_node” service is not present in the drop-down menu with services. When I manually write in the Service field “zwave/add_node” and press the button “Call Service”, nothing happens.
So my questions is: What command I need to send or how I can setup the service in the configuration.yaml so it shows in the drop-down menu with the available services.
Thanks,¨
Simon
