How to add an icon to a button on an ESPHome + LVGL display
I have this ESPHome configuration for my ESP32 console Lilka. I have three buttons on the screen. They display Voltage, Battery %, and a button with the text Lilka LVGL.
How can I add an icon to this text?
esphome:
  friendly_name: lilka
  on_boot:
    priority: 600
    then:
      - output.turn_on: display_power
      - delay: 100ms
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    version: recommended
    # Оптимізація пам'яті
    sdkconfig_options:
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: y
      CONFIG_SPIRAM_MODE_OCT: y
      CONFIG_SPIRAM: y
# Додати якщо є PSRAM
psram:
  mode: octal
  speed: 80MHz
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: none
  ap:
    ssid: "Lilka Fallback Hotspot"
    password: "hnYImYM4O6I0"
captive_portal:
web_server:
  port: 80
api:
  encryption:
    key: "Yw3yq8lxsaze+jdggjAwxKpV4GD6gNZptvw4d6OPfOc="
logger:
  level: INFO
  logs:
    lvgl: WARN
    speaker_media_player: INFO
    i2s_audio.speaker: INFO
ota:
  - platform: esphome
    password: "bb198feb99159fdaefc8092f10039acd"
output:
  - platform: gpio
    pin: 46
    inverted: false
i2s_audio:
  - id: i2s_out
    i2s_lrclk_pin: GPIO1
    i2s_bclk_pin: GPIO42
speaker:
  - platform: i2s_audio
    dac_type: external
    i2s_audio_id: i2s_out
    i2s_dout_pin: GPIO2
    channel: mono
    sample_rate: 16000
    bits_per_sample: 16bit
    buffer_duration: 100ms
media_player:
  - platform: speaker
    name: "Lilka Media Player"
    buffer_size: 4000
    codec_support_enabled: false
    announcement_pipeline:
        speaker: lilka_speaker
        format: WAV
        num_channels: 1
# СЕНСОРИ
  - platform: adc
    pin: GPIO3
    icon: "mdi:lightning-bolt"
    update_interval: 10s
    attenuation: 12db
    filters:
      - multiply: 1.33
    icon: "mdi:battery"
    unit_of_measurement: "%"
    accuracy_decimals: 0
    lambda: |-
      float voltage = id(battery_voltage).state;
      float percent = (voltage - 3.0) / (4.2 - 3.0) * 100.0;
      if (percent > 100) percent = 100;
      if (percent < 0) percent = 0;
      return percent;
# ДИСПЛЕЙ ST7789V + LVGL
spi:
  clk_pin: 18
  mosi_pin: 17
display:
  - platform: mipi_spi
    model: ST7789V
    dc_pin: 15
    cs_pin: 7
    update_interval: 2s
    rotation: 270
    invert_colors: true
    color_order: BGR
    pixel_mode: 16bit
    dimensions:
      width: 280
      height: 240
      offset_width: 20
      offset_height: 0
    auto_clear_enabled: false
lvgl:
  log_level: WARN
  buffer_size: 25%
  style_definitions:
    - id: default_style
      bg_color: 0x000000
      text_color: 0xFFFFFF
    - id: focused_style
      border_color: 0xFFFFFF
      border_width: 3
  pages:
    - id: main_page
      bg_color: 0x000000
      widgets:
        - button:
            align: CENTER
            y: -40
            width: 180
            height: 50
            bg_color: 0xFF0000
            widgets:
              - label:
                  text: "Battery: --"
                  align: CENTER
        - button:
            align: CENTER
            y: 20
            width: 180
            height: 50
            bg_color: 0x00FF00
            widgets:
              - label:
                  text: "Voltage: --"
                  align: CENTER
                  text_color: 0x000000
        - button:
            align: CENTER
            y: 80
            width: 180
            height: 50
            bg_color: 0x0000FF
            widgets:
              - label:
                  text: "Lilka LVGL"
                  align: CENTER
# ГЛОБАЛЬНІ ЗМІННІ ТА СКРИПТ ФОКУСУ
globals:
  - id: current_button_index
    type: int
    restore_value: no
    initial_value: '0'
script:
  - id: update_focus
    then:
      - lvgl.widget.update:
          border_width: !lambda 'return id(current_button_index) == 0 ? 3 : 0;'
          border_width: !lambda 'return id(current_button_index) == 1 ? 3 : 0;'
          border_width: !lambda 'return id(current_button_index) == 2 ? 3 : 0;'
# КНОПКИ
binary_sensor:
  - platform: gpio
    pin:
      number: 38
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:arrow-up-circle"
    filters:
      - delayed_on_off: 50ms
    on_press:
      - lambda: |-
          id(current_button_index)--;
          if (id(current_button_index) < 0) id(current_button_index) = 2;
      - script.execute: update_focus
  - platform: gpio
    pin:
      number: 41
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:arrow-down-circle"
    filters:
    on_press:
      - lambda: |-
          id(current_button_index)++;
          if (id(current_button_index) > 2) id(current_button_index) = 0;
  - platform: gpio
    pin:
      number: 39
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:arrow-left-circle"
    filters:
  - platform: gpio
    pin:
      number: 40
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:arrow-right-circle"
    filters:
  - platform: gpio
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:alpha-a-circle"
    filters:
  - platform: gpio
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:alpha-b-circle"
    filters:
  - platform: gpio
    pin:
      number: 10
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:alpha-c-circle"
    filters:
  - platform: gpio
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:alpha-d-circle"
    filters:
  - platform: gpio
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:play-circle"
    filters:
  - platform: gpio
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: true
    icon: "mdi:checkbox-marked-circle"
    filters:
# ОНОВЛЕННЯ СТАТУСУ БАТАРЕЇ НА ЕКРАНІ
interval:
  - interval: 5s
    then:
      - lvgl.label.update:
          text: !lambda |-
            return std::string("Battery: ") + to_string((int)id(battery_level).state) + "%";
          text: !lambda |-
            char buf[20];
            snprintf(buf, sizeof(buf), "Voltage: %.2fV", id(battery_voltage).state);
            return std::string(buf);
You need to use fonts.
Thank you, everything works. I’m using the pre-rendered Monserrat font in the LVGL library along with its icons.
              - button:
                  width: 180
                  height: 50
                  bg_color: 0x00FF00
                  widgets:
                    - label:
                        text: "Voltage: --"
                        align: CENTER
                        text_color: 0x333333
                        text_font: montserrat_22
interval:
  - interval: 5s
    then:
          text: !lambda |-
            return std::string("\uF240 ") + to_string((int)id(battery_level).state) + "%";
