Hi! Got a problem with connecting 1-wire devices. I had connected 28-* temperature sensor connectied and working, however when I connected DS2406 - nothing happened: I still have only one 1-wire integration.
Right now I have following connections:
ls /sys/bus/w1/devices/
12-000000dd7494 28-02151538c4ff w1_bus_master1
26-000002558e77 3a-0000005ab050
and can’t understand what I have to do in order to add 12-* and 26-* devices integrations to Home Assistant. Any help appriciated, thanks in advance!
platform: onewire via gpio ds18b20 works - But ds2408 ds2406 does not work integration into HA> 1-wire> OWServer? I have not found such integration Could you direct me how to create OWServer via hass.io usb DS9490R or i2c ds2482? I’m deadlocked
I’ve bought a DS9490R and installed OWFS (OWserver) on a Raspberry Pi. OWserver is running and connected to Home Assistant, the only thing I’ve to solve yet is connecting the temp sensors to the DS9490R.
I’ve connected a DS18B20 to a RJ11 connector and connected it to the DS9490R but doens’t work… I’ve followed the wiring diagram correctly. Does anybody know if I need to feed it with a external 5V power supply or is the voltage come from the USB port?
