How to add "element card" to floorplan?
I have made a floor plan and am happy with it. Now I want the status of the alarm system to be visible right at the bottom of the floor plan. Now I’ve done that with Colton YYZ. But, now i cant get it to work on the floorplan. can someone teach me how to add another card between the existing yaml code? When I do this now the icon simply does not appear.
en hieronder de code van de floorplan:
kiosk_mode:
  hide_header: true
  - title: Floorplan
    type: panel
    path: first
    badges: []
    cards:
      - type: horizontal-stack
        cards:
          - type: picture-elements
            image: /local/map/3D/Basis.png
            panel: true
            elements:
              - type: image
                entity: light.verlichting_gang_beneden_ikea_light_2
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  mix-blend-mode: lighten
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.verlichting_gang_beneden_ikea_light_2’].attributes.hs_color
                    states[‘light.verlichting_gang_beneden_ikea_light_2’].attributes.hs_color[0]
                    : 0) + "deg)"}
                      opacity: >-
                    ${states[‘light.verlichting_gang_beneden_ikea_light_2’].state
                    === 'on' ?
                    (states[‘light.verlichting_gang_beneden_ikea_light_2’].attributes.brightness
                    / 255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-halletje.png
                  'off': /local/map/3D/Basis.png
                tap_action:
                  action: none
              - type: image
                entity: light.keukenblad
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.keukenblad’].attributes.hs_color ?
                    states[‘light.keukenblad’].attributes.hs_color[0] : 0) +
                    "deg)"}
                  opacity: >-
                    ${states[‘light.keukenblad’].state === 'on' ?
                    (states[‘light.keukenblad’].attributes.brightness / 255) :
                    '0'}
                state_image:
                  'on': /local/map/3D/bg-keukenblad2.png
                tap_action:
                  action: none
              - type: image
                entity: light.hal
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" + (states[‘light.hal’].attributes.hs_color
                    ? states[‘light.hal’].attributes.hs_color[0] : 0) + "deg)"}
                  opacity: >-
                    ${states[‘light.hal’].state === 'on' ?
                    (states[‘light.hal’].attributes.brightness / 255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-hal-vide.png
                tap_action:
                  action: none
              - type: image
                entity: light.keuken_raam
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.keuken_raam’].attributes.hs_color ?
                    states[‘light.keuken_raam’].attributes.hs_color[0] : 0) +
                    "deg)"}
                  opacity: >-
                    ${states[‘light.keuken_raam’].state === 'on' ?
                    (states[‘light.keuken_raam’].attributes.brightness / 255) :
                    '0'}
                state_image:
                  'on': /local/map/3D/bg-keukenverlichting-raam.png
                tap_action:
                  action: none
              - type: image
                entity: light.woonkamer
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.woonkamer’].attributes.hs_color ?
                    states[‘light.woonkamer’].attributes.hs_color[0] : 0) +
                    "deg)"}
                  opacity: >-
                    ${states[‘light.woonkamer’].state === 'on' ?
                    (states[‘light.woonkamer’].attributes.brightness / 255) :
                    '0'}
                state_image:
                  'on': /local/map/3D/bg-woonkamer.png
                tap_action:
                  action: none
              - type: image
                entity: light.eethoek
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.eethoek’].attributes.hs_color ?
                    states[‘light.eethoek’].attributes.hs_color[0] : 0) +
                    "deg)"}
                  opacity: >-
                    ${states[‘light.eethoek’].state === 'on' ?
                    (states[‘light.eethoek’].attributes.brightness / 255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-eetkamer.png
                tap_action:
                  action: none
              - type: image
                entity: switch.switch_wc_beneden_switch
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘switch.switch_wc_beneden_switch’].attributes.hs_color
                    states[‘switch.switch_wc_beneden_switch’].attributes.hs_color[0]
                    : 0) + "deg)"}
                  opacity: >-
                    ${states[‘switch.switch_wc_beneden_switch’].state === 'on' ?
                    (states[‘switch.switch_wc_beneden_switch’].attributes.brightness
                    / 255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-wclamp.png
                tap_action:
                  action: none
              - type: image
                entity: light.hal_bg_licht
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.hal_bg_licht’].attributes.hs_color ?
                    states[‘light.hal_bg_licht’].attributes.hs_color[0] : 0) +
                    "deg)"}
                  opacity: >-
                    ${states[‘light.hal_bg_licht’].state === 'on' ?
                    (states[‘light.hal_bg_licht’].attributes.brightness / 255) :
                    '0'}
                state_image:
                  'on': /local/map/3D/bg-bg-hala8.png
                tap_action:
                  action: none
              - type: image
                entity: scene.alle_verlichting_uit
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" + (states[‘scene.alle_verlichting_uit
                    ’].attributes.hs_color ? states[‘scene.alle_verlichting_uit
                  opacity: >-
                    ${states[‘scene.alle_verlichting_uit’].state === 'on' ?
                    (states[‘scene.alle_verlichting_uit’].attributes.brightness
                    / 255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-alleverlichtinguit.png
                tap_action:
                  action: none
              - type: image
                entity: light.staande_lamp_licht
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘light.staande_lamp_licht’].attributes.hs_color ?
                    states[‘light.staande_lamp_licht’].attributes.hs_color[0] :
                    0) + "deg)"}
                  opacity: >-
                    ${states[‘light.staande_lamp_licht’].state === 'on' ?
                    (states[‘light.staande_lamp_licht’].attributes.brightness /
                    255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-staandelamp.png
                tap_action:
                  action: none
              - type: image
                entity: scene.nachtstand
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘scene.nachtstand’].attributes.hs_color ?
                    0) + "deg)"}
                  opacity: >-
                    ${states[‘scene.nachtstand’].state === 'on' ?
                    (states[‘scene.nachtstand’].attributes.brightness / 255) :
                    '0'}
                state_image:
                  'on': /local/map/3D/bg-nachtstand.png
                tap_action:
                  action: none
              - type: image
                entity: cover.gordijnen_raambekleding
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    (states[‘cover.gordijnen_raambekleding’].attributes.hs_color
                    states[‘cover.gordijnen_raambekleding’].attributes.hs_color[0]
                    : 0) + "deg)"}
                      opacity: >-
                    ${states[‘cover.gordijnen_raambekleding’].state === 'on' ?
                    (states[‘cover.gordijnen_raambekleding’].attributes.brightness
                    / 255) : '0'}
                state_image:
                  'on': /local/map/3D/bg-gordijnen-100.png
                tap_action:
                  action: none
              - type: image
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
                    ${ "hue-rotate(" +
                    0) + "deg)"}
                  opacity: >-
                    '0'}
                state_image:
                tap_action:
                  action: none
              - type: state-icon
                style:
                  top: 32%
                  left: 29%
                  opacity: 0
                  '--mdc-icon-size': 180px
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 25%
                  top: 65%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: state-icon
                entity: light.hal
                style:
                  left: 45%
                  top: 45%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 13%
                  top: 61%
                  opacity: 0
                  '--mdc-icon-size': 140px
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 73%
                  top: 37%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 56%
                  top: 57%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 32%
                  top: 50%
                  opacity: 0
                  '--mdc-icon-size': 60px
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 47%
                  top: 35%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 88%
                  top: 54%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: state-icon
                style:
                  left: 15%
                  top: 24%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: service-button
                title: NIGHT
                service: script.nachtstand
                style:
                  top: 13%
                  left: 11%
                  opacity: 0
                tap_action:
                  action: toggle
              - type: icon
                title: Voordeur deurbel
                icon: mdi:cctv
                entity: camera.deurbel_vloeiend
                style:
                  top: 21%
                  left: 11%
                  opacity: 0
                  '--mdc-icon-size': 55px
              - type: state-icon
                style:
                  left: 20%
                  top: 16%
                  width: 30%
                  opacity: 0
                  '--mdc-icon-size': 50px
                tap_action:
                  action: toggle
                title: DAYST
                service: script.alarm_uitschakelen
                style:
                  top: 8%
                  left: 16%
                  opacity: 0
                  '--mdc-text-size': 50px
                tap_action:
                  action: toggle
    visible:
      - user: xxx
    layout: {}
En hieronder de code van het icon:
elements:
  - type: image
    image: null
    entity: alarm_control_panel.nachtstand
    name: Alarm System Status
    style:
      left: 50%
      top: 55%
      width: 50%
    state_image:
      armed_home: /local/map/3D/shield/red.gif
      disarmed: /local/map/3D/shield/white.png
image: /local/map/3D/shield/trans.png
dark_mode_image: /local/map/3D/shield/white.png
Can anyone tell me what to do and how?
thank you!
You need to change the dark mode image:
to:
dark_mode_image: /local/map/3D/shield/trans.png
Also, the whole picture elements needs to be placed inside your floorplan.
kiosk_mode:
  hide_header: true
  - title: Floorplan
    type: panel
    path: first
    badges: []
    cards:
        elements:
        - type: image
          image: null
          style:
            left: 50%
            top: 55%
            width: 50%
          state_image:
        cards:
            panel: true
            elements:
              - type: image
Then the rest of your code....
Sorry for the bad formatting. I’m on my phone and can’t keep the correct formatting for some reason.
Hi!
If i do this:
kiosk_mode:
  hide_header: true
  - title: Floorplan
    type: panel
    path: first
    badges: []
    cards:
        elements:
        - type: image
          image: null
          style:
            left: 50%
            top: 55%
            width: 50%
          state_image:
        cards:
            panel: true
            elements:
              - type: image
                style:
                  left: 50%
                  top: 50%
                  width: 100%
                  filter: >-
Then i get an error: See the yellow line on top:
the text says: this view has more than 1 card but a panel view can only contain 1 card.
