Hi all,
I’m trying to add the new Energy Monitoring feature to the lightwaverf energy monitor however I’m struggling to understand exactly how this all works.
I’ve updated my code so that I’m importing the DEVICE_CLASS_POWER and STATE_CLASS_MEASUREMENT however I’m still getting “No Matching Statistics Found” when I try and add the energy monitor as a source under Configure Grid Consumption.
The code I have to initialise the sensor is as follows:
from homeassistant.components.sensor import PLATFORM_SCHEMA, STATE_CLASS_MEASUREMENT
from homeassistant.const import CONF_SCAN_INTERVAL, DEVICE_CLASS_POWER
# ... other code ...
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Configure the sensor platform for home assistant."""
scan_interval = hass.data[DATA_KEY]
_LOGGER.info("scan interval= %s", scan_interval)
lightwave_devices = [
LightwaveEnergy("CURRENT_USAGE", scan_interval, DEVICE_CLASS_POWER, STATE_CLASS_MEASUREMENT),
LightwaveEnergy("TODAY_USAGE", scan_interval, DEVICE_CLASS_POWER, STATE_CLASS_MEASUREMENT),
add_devices(lightwave_devices)
class LightwaveEnergy(Entity):
"""Primary class for Lightwave Energy."""
def __init__(self, sensor_type, scan_interval, device_class, state_class):
"""Initialize the sensor."""
_LOGGER.info("Lightwave Energy Init , scan interval=%s", scan_interval)
self.sensor_type = sensor_type
self.serial = ""
self.mac = ""
self.current_usage = ""
self.today_usage = ""
self.lightwave_energy_data = None
self.scan_interval = scan_interval
self._updatets = time.time()
self._attr_device_class = device_class
self._attr_state_class = state_class
and the resource details from the developer tool box for each of the two measurements returned is as follows:
# sensor.electricity_current_useage_w
unit_of_measurement: W
friendly_name: Electricity Current Usage (W)
icon: mdi:flash
device_class: power
# sensor.electricity_energy_today_usage_kwh
unit_of_measurement: kWh
friendly_name: Electricity Energy Today Usage (kWh)
icon: mdi:flash
device_class: power
The docs mention a STATE_CLASS_TOTAL_INCREASING option for the sensor state, however that doesn’t appear to be available in the version I’m running:
System Health
| version | core-2021.8.8 |
| installation_type | Home Assistant Core |
| dev | false |
| hassio | false |
| docker | false |
| user | homeassistant |
| virtualenv | true |
| python_version | 3.8.7 |
| os_name | Linux |
| os_version | 5.10.52-v7+ |
| arch | armv7l |
| timezone | Europe/London |
Home Assistant Community Store
| GitHub API | ok |
| Github API Calls Remaining | 3906 |
| Installed Version | 1.14.1 |
| Stage | running |
| Available Repositories | 881 |
| Installed Repositories | 38 |
Home Assistant Cloud
| logged_in | true |
| subscription_expiration | 17 September 2021, 1:00 |
| relayer_connected | true |
| remote_enabled | false |
| remote_connected | false |
| alexa_enabled | true |
| google_enabled | false |
| can_reach_cert_server | ok |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
If anyone can point me in the direction of an explainer on how to add this functionality to an existing code-base, that would be amazing!
