- service: homeassistant.turn_on
entity_id: >
- light.kitchen_glass
- light.kitchen
- switch.socket1
{% if states('sun.sun') = 'below_horizon' %}
- light.fibaro_system_fgd212_dimmer_2_level_4
{% endif %}
please, help!
how fix it?
I got error:
Invalid config for [automation]: not a valid value for dictionary value @ data['action'][0]['entity_id']. Got None. (See /config/configuration.yaml, line 327). Please check the docs at https://home-assistant.io/integrations/automation/
tom_l
January 14, 2020, 8:48am
2
You don’t need a template. This is where you would use a condition in the action block.
entity_id:
- light.kitchen
- switch.socket1
- condition: state # from sunset until sunrise
entity_id: sun.sun
state: 'below_horizon'
entity_id: light.fibaro_system_fgd212_dimmer_2_level_4
Though if you really want to use a template you could try this:
data_template:
entity_id: >
{% if states('sun.sun') == 'above_horizon' %}
- light.kitchen
- switch.socket1
{% else %}
- light.kitchen
- switch.socket1
{% endif %}
Note the use of “data_template” and “==” not “=”.
== is a test (does x == y)
= assigns a value ( set x = y)
Second one won’t work, you can’t output a list in jinja.
First one is the solution.
tom_l
January 14, 2020, 9:05am
4
I was wondering about that, which is why I said “try”.
Not even a comma separated list?
Comma separated string output works with some services and not others, best to avoid, but probably would work in this one to be fair.
tom_l
January 14, 2020, 9:09am
6
Ok so, @dmitry.mukhach to be clear, this template below might work, but it would still be best to use the first solution I provided that uses the condition in the action block.
data_template:
entity_id: >
light.kitchen_glass, light.kitchen, switch.socket1
{% else %}
light.kitchen_glass, light.kitchen, switch.socket1, light.fibaro_system_fgd212_dimmer_2_level_4
{% endif %}
No, this not work
data_template:
entity_id: >
{% else %}
{% endif %}
It was validated but wen run - nothing turn on.
Thanks a lot! With condition works
