Hi
I have a supervised install of Home Assistant and I am trying to add the Evohome (Europe) integration. It does not come up in the search but is available in Github. I just can’t work out why or how to install it?
Thanks in advance
Hi
Thanks in advance
It can’t be set up from UI. You’ll have to add it manually to your configuration.yaml
according to the documentation.
Thanks - I was unaware of this and giving a go now.
See Configuration.yaml - Home Assistant for more details.
