I added some button cards to lovelace and works fine.
But it doesnt appeard in my Apple home app.
How to transfer those button to Apple Home?
Hi colvins, welcome to the forums!
Have you installed https://www.home-assistant.io/integrations/homekit/ ?
yes
i have installed homekit.
And in which way it is configured? Do you expose the lights to Homekit you want to see in the app?
I am using a Xiaomi IR to remote my old lights.
No, I mean, what have you configured in the homekit integration?
You have to add them to the homekit.yaml file
I didn’t configured anything.
Ok, when you say you have installed the Homekit integration, you have to configure it for your needs. This can be done on the integration page (settings → integrations) or via yaml file as BertrumUK mentioned.
The remote can be found in the Home app,but the button which i add in the lovelace still can’t be found.
I assumed that a real light entity exists. When the controlled lights are dumb I’m not aware of a way to expose more than the remote control in Homekit.
Thank you very much.
So there is no way to add those buttons to Apple home?
Why not make them a script in HA? And make sure to add this script to the HomeKit entities.
Or use a template switch/light.
Yes,I made them in script and it does worked.
Thank you very much!
Today’s video, I’m going to show you how to set up and configure Lovelace on Home … Create Your Own Apple HomeKit Enabled Projects Using The Raspberry Pi.
krogerfeed
