How to add "more-info" on the dashboard
Good Morning,
I have a binary sensor (leak sensor) that is correctly displayed on the dashboard.
The sensor is calleable as: “binary_sensor.water_leak_sensor_IDNUMBER”, if i click on this element “more-info” i can see different information like voltage & battery level.
How can i move directly this information on the dashboard without click on the item to show it?
regards
Gianluca
You can use the binary sensor template to get more informations:
For example (put the code in configuration.yaml):
    sensors:
      water_leak_sensor:
       friendly_name: "Water leak sensor battery"
       unit_of_measurement: "%"
       value_template: "{{ state_attr('binary_sensor.water_leak_sensor_IDNUMBER', 'Battery') }}"
Correction: Template sensor. Not template binary sensor. They are analogue attributes.
    sensors:
      wcf_battery:
        friendly_name: "WCF battery"
        entity_id: binary_sensor.water_leak_sensor_IDNUMBER
        device_class: battery
        value_template: "{{ state_attr('binary_sensor.water_leak_sensor_IDNUMBER', 'battery level') }}"
      wcf_votage:
        friendly_name: "WCF Voltage"
        unit_of_measurement: 'V'
        icon: mdi:flash
        value_template: "{{ state_attr('binary_sensor.water_leak_sensor_IDNUMBER', 'voltage') }}"
Using the battery device class for the battery sensor will give different battery level icons depending on the battery state.
Screenshot_2020-02-27 Home Assistant(1)
You are right! Sorry, I am still half asleep. :sleeping:
Thanks a lot fot the reply.
My idea is to have a for each sensor in dashboard the same panel displayed on more-info:
In addition instead of “13 hour ago” that is the “last-changed” value…i prefer have the last time that the sensor is switched from off to on.
Im asking too much ? :slight_smile:
There’s a custom more-info card, and guess who did it?
Thanks guys,
I have tried your code and work fine!! Thanks!!
In addition instead of “13 hour ago” that is the “last-changed” value…i prefer have the last time that the sensor is switched from off to on. How can i implement this message ?
