I am based in Perth, Western Australia. We have some of the cheapest solar system’s. My goal is to:
- Maximise utilisation of the Solar PV system
- Minimise costs from the electricity grid using the Synergy Time of Use tariff (Synergy EV Home Plan – Electric Vehicle Add On Rates & Prices)
- Educate my family on how to utilise equipment for lowered run costs
- Get my wife on-board for all the future home automation things I will buy
What i have in my setup
- Home Assistant
- HACS Add-On
- Solar Inverter
- CT Clamp system
- YAML (copy and paste)
What my dashboard looks like
Home Assistant : My HA has moved hosts from RPi3, RPi4 and is now a proxmox host using docker. Here is a decent video on the setup https://youtu.be/GoZaMgEgrHw?si=93vuW5ok_2tqP6RX
Home Assistant Community Store (HACS) I quickly noticed I needed to use some of the more beta features of HA which essentially all live in HACS. Here is a 6min video on getting HACS running https://youtu.be/oXaGqjaKbeE?si=J9XsgG_WVJfYnUQq
Solar Inverter I have an old Delta 5kW to connect to my 3-phase (3P) meter box. Any PV system will do. If I was to buy again I would pick a Fronius Gen24 system as they have a free/native API that can give you generation data to be used with the energy module in HA.
CT Clamps I am using the Shelly 3EM, this local-only wifi device lives in my meter box and is only clamped over my mainlines to tell me net consumption/ generation. Here is a video from my sparky on the setup https://youtu.be/kDIK0BP4Xss?si=Gjp97ST3gm4r9bQc
DISCLAIMER: I am a tight-ass and only installed 1 of these unit’s I would recommend 2 if I was to do this again so I can see what I generated.
HA Energy Dashboard Since only have a single unit production on my dashboards is only what I sold back to the grid, NOT what was produced. As I am in Perth on a summer’s day I produce around 37 to 42kWh a day.
Here is a fairly nice day of generation
YAML, automation… yuck: So to get pricing right you need to define a time of use automation.
You will need to configure the Utility Meter here is a great video for getting this done generically. https://youtu.be/W7mVagcssZY?si=HGengkN3V8VuTl1J
Here is the code you need for the variable time-of-use tariff
3P Channel A
alias: TOU Energy Tariffs CH:A
description: Synergy WA
- platform: time
at: input_datetime.tou_06_00_off_peak
variables:
tariff: Off Peak
- platform: time
at: input_datetime.tou_09_00_super_off_peak
variables:
tariff: Super Off Peak
- platform: time
at: input_datetime.tou_15_00_peak
variables:
tariff: Peak
- platform: time
at: input_datetime.tou_21_00_off_peak
variables:
tariff: Off Peak
- platform: time
at: input_datetime.tou_23_00_overnight
variables:
tariff: Overnight
- service: select.select_option
entity_id: select.tou_em_channel_a_energy
option: "{{ tariff }}"
mode: single
3P Channel B
alias: TOU Energy Tariffs CH:B
- platform: time
variables:
tariff: Off Peak
- platform: time
variables:
- platform: time
variables:
tariff: Peak
- platform: time
variables:
tariff: Off Peak
- platform: time
variables:
tariff: Overnight
entity_id: select.tou_em_channel_b_energy
mode: single
3P Channel C
alias: TOU Energy Tariffs CH:C
- platform: time
variables:
tariff: Off Peak
- platform: time
variables:
- platform: time
variables:
tariff: Peak
- platform: time
variables:
tariff: Off Peak
- platform: time
variables:
tariff: Overnight
entity_id: select.tou_em_channel_c_energy
mode: single
What my dashboard looks like in the real world. This is the most central location in the house (next to the fridge). I feel this does the following:
- expansion of traditional/physical things and systems
- quickly tells me what I need to know high-level on energy usage
- gamification of mobile device’s charge status to raise awareness for my kids
