I am still working on my Dashboard and was fascinated by a button that showed a symbol of the room and temp and humidity in same button…
Now i got close but cant find out to get room pictures into it and/or determine what info appears or not…
Attached is the example pic/code and i am a little lost…
Thx for any help
The thread contains “custom:mushroom-template-card” word.
But you are asking “how to add room pictures to Area cards”, right?
These are different things.
well…i was hoping…since i am not quiet sure what i am doing, that the code is giving a hint where i am coming from. With area cards i do mean the colored cards on the rigyt side with the temps and all…
Are you saying that after adding an image for an area you can see only a temperature sensor on the card - although BEFORE adding the image you also saw other sensors?
Yes, as shown in my initial message with the screenshots, you can see temp and humidity and a switch or more if a room has switches…with the bedroom having a picture now, the temp and the humidity went away. or got put behind the picture, not sure how this card is organized.
I also haven’t found a way to determine what is shown, switches or temp/humidity…so any help if highly appreaciated…cause my final goal is to have a pic of the room with temp and humidity on top as first glance info
