Hassio, 77.2.
I had to make a command line sensor that uses curl to get the token from the remote instance of ha where the pi is running
- platform: command_line
name: Garage Pi Cam Token
command: curl -X GET http://192.168.20.222:8123/api/states/camera.raspberry_pi_camera?api_password=topsecret!
value_template: '{{ value_json.attributes.access_token}}'
Then I had to change my camera to pull that info from the sensor.
- platform: generic
still_image_url: http://192.168.20.222:8123/api/camera_proxy/camera.raspberry_pi_camera?token={{states.sensor.garage_pi_cam_token.state}}&time=1486408118004
I still have the same config in my remote pi running ha.
camera:
- platform: rpi_camera
image_quality: 7
image_rotation: 180
I dont use hassio and dont know much about docker so I am not sure of the limitations there. I do know that the new auth and removal of remote.api have been tough on me but it is probably for the better.
where can i find this option?
Unfortunately, this method stops working since 0.109.4. Token doesnāt update in still_image_url parameter.
Hello everyone, I cannot get a general Rasberry Pi camera to work.
I am on HassOS 4.10 with Home Assistant 0.110.6 on a Rasberry Pi 3 B+.
The camera: https://www.aliexpress.com/item/32726563700.html
I have used the integration: Raspberry Pi Camera
I have added the following in my configuration.yaml
rpi_camera:
name: 3D printer camera
I have no error messages in the log.
Under developer tools / states I see the camera: camera.3d_printer_camera and it shows idle.
When I press the little i (info) I do not see any image.
When I add it to lovelace i do not get to see any image:
aspect_ratio: 50%
camera_image: camera.raspberry_pi_camera
entity: camera.3d_printer_camera
show_state: true
tap_action:
action: toggle
type: picture-entity
The picture should be here:
entity_picture: /api/camera_proxy/camera.3d_printer_camera?token=[token]
However, I cannot find the folder api anywhere, using the file editor.
The documentation suggest that the file_path should be whitelisted, but I do not have āhome assistant:ā in my configuration.yaml so i have no clue where to add thatā¦
What should I do? What can I do to make it work?
Hi everybody,
Digging so deep to find a solution for my RPi-cam module.
Is anybody dare to make it functionning ?
Thanks in advance.
Take care. Gaƫtan
This is my config :
docker: 19.03.8
hassos: ā4.10ā
homeassistant: 0.111.2
hostname: homeassistant
logging: info
machine: raspberrypi4
supervisor: ā227ā
I also couldnāt get the Raspberry PI camera to work. Itās also shown on the entity list.
The ā/api/camera_proxy/ā¦ā thing looks like an endpoint URL of HA. Iāve tried to access it using āhttp://[My Home Assistant IP and port]/api/camera_proxy/ā¦ā and HA returns the message ā500: Internal Server Errorā.
Iām using Raspberry Pi 3 model B and Raspberry Pi Camera v2.1. The rest of my config is:
arch | armv7l |
chassis | embedded |
dev | false |
docker | true |
docker_version | 19.03.11 |
hassio | true |
host_os | HassOS 4.12 |
installation_type | Home Assistant OS |
os_name | Linux |
os_version | 4.19.127-v7 |
python_version | 3.8.3 |
supervisor | 234 |
version | 0.114.1 |
virtualenv | false |
Hello!
came here for the same problem as above, Iām also new to this and currently running ha core in docker. (Couldnāt get it to work on Hassos either) The rpi camera is there as an entity and the status showing as idle. What are/were we all missing here to get the camera to show an image?
EDIT: this is what worked for me, in case another docker newbie like me is looking for answers here: running the docker Container āprivileged
