i tried couple of ways but i cant get camera in dashboard
1, i make cameras.yaml file with
camera:
platform: rpi_camera
name: Raspberry Pi Camera
image_width: 640
image_height: 480
image_quality: 7
image_rotation: 0
timelapse: 1000
horizontal_flip: 0
vertical_flip: 0
file_path: /tmp/image.jpg
and put camera: include devices/cameras.yaml
but nothing happens after that i put this code in configuration.yaml
same prob please help me
68hc11
(Calvin)
June 18, 2016, 6:18pm
2
Are you using the camera port on the HA raspberry or an additional raspberry?
im using camera port in same raspberry pi 3
Landrash
(Landrash)
June 19, 2016, 7:32am
4
Does the camera work with raspistill outside of HA?
Landrash
(Landrash)
June 19, 2016, 3:32pm
6
Just reread your first post.
Your include should be similar to this.
camera: !include devices/cameras.yaml
And your cameras file devices/cameras.yaml
- platform: rpi_camera
image_width: 640
image_height: 480
image_quality: 7
image_rotation: 0
timelapse: 1000
horizontal_flip: 0
vertical_flip: 0
As is now you got the camera:
part twice.
Thaks sir to help but i tried that way im not get any error when restart but i cant get anything in dashboard.
jarjar26
(Michael Lessard)
December 18, 2016, 12:04am
8
I have the same situation here, any other trick to make it works ?
thx
jarjar26
(Michael Lessard)
December 19, 2016, 9:01pm
9
I fount it , i need to add the user hass to the video group :
usermod -a -G video hass
turboc
(Chip Cox)
December 29, 2016, 2:46pm
10
I’m thinking about doing this. You mentioned having the camera hooked up via an additional raspberry. Could you go over that setup?
turboc
(Chip Cox)
January 8, 2017, 8:38pm
11
Can someone go over the configuration steps to add a camera that is installed on a different RPI to HA. I want to setup several of these for monitoring the doors around the house and in my shop.
PtP
(Mike)
February 7, 2017, 2:17pm
12
I have HA running on a Pi with a cam. This is not my main instance however.
I just copied the image address and added it to a generic cam on my main instance.
turboc
(Chip Cox)
February 7, 2017, 2:50pm
13
Are you just getting a still image, or video?
What software are you using on your HA with the PI
PtP
(Mike)
February 7, 2017, 3:10pm
14
It is a still image but updates every second.
I am not using anything special on the pi. It is a pi cam using the picam component.
jwilker2
(Jwilker2)
May 16, 2017, 12:46pm
15
Would you be kind enough to post an example of your solution?
This could help - posts still images from a seperate pi.
Not been able to get a live stream on the HA UI, but there are packages if you are happy with a stream to a seperate page, see https://picamera.readthedocs.io/en/release-1.13/recipes2.html#web-streaming
PtP
(Mike)
May 17, 2017, 5:13pm
17
@jwilker2
Once again I have 2 instances of HA…
The garage instance has the pi cam.
camera:
image_quality: 7
image_rotation: 180
My main instance has a generic camera with the image url.
- platform: generic
still_image_url: http://192.168.200.115:8903/api/camera_proxy/camera.raspberry_pi_camera?token=123wergjb0uwhr0beofwlseii56e2b74eb3oidfhgusdbw5&time=1434667678004
I got the url by clicking on the cam in my garage instance of HA to view it and then right clicking on the cam and selecting the COPY IMAGE ADDRESS option.
I simply pasted it into the generic cam in my main instance.
How did you get the camera working in HA. I have the same config for rpi_camera, but mine refuses to show up.
PtP
(Mike)
September 5, 2018, 9:21pm
20
If you are using the latest version of ha it gets tricky because the token changes. What flavor of ha are you using and what version?
