Iam using xiaomi flora, scan_interval was set to 5 min. But sometime I want it update the value instantly, is there any way to add scan_interval to the script so I can create the button in HA dashboard ?
My idea is:
_Press the button, scan_interval will set to 1 sec.
_Delay 2 sec
_Then set scan_interval back to 5 min
I tried, but it didnt work with BLE device
How did you set up the 5min interval ?
So what does your current config look like to update the entity ?
Your pic seems to have a lot of dandruff
In configuration.yaml, sensor will look like this:
- platform: miflora
mac: C4:7C:8D:64:F9:58
monitored_conditions:
- moisture
- temperature
- conductivity
- light
- battery
force_update: true
scan_interval: 300
I just dont know how to transfer it to the script yet
So as VDR says and you replied … you tried : -
- alias: 'au_miflora_update'
- platform: time_pattern
minutes: '/1'
- service: homeassistant.update_entity
entity_id: sensor.soil_sensor1
Does nothing ?
Not sure that your sensor name should not be all in lower case
Having said that …
Your sensor set up looks weird
I would have thought it should look like this : -
- platform: miflora
sensors:
soil_sensor1:
friendly_name: Soil Sensor 1
- moisture
- temperature
- conductivity
- light
- battery
force_update: true
scan_interval: 300
soil_sensor2:
friendly_name: Soil Sensor 2
mac: C4:7C:8D:64:F9:59
- moisture
- temperature
- conductivity
- light
- battery
force_update: true
scan_interval: 300
soil_sensor3:
friendly_name: Soil Sensor 3
mac: C4:7C:8D:64:F9:60
- moisture
- temperature
- conductivity
- light
- battery
force_update: true
scan_interval: 300
etc.
I fix the name and add automation as you said, still nothing :(.
Okay, we may have to wait till someone more experienced with bluetooth comes to the thread.
Just to be sure though - the above ‘fix’ didn’t break your sensor did it ? (I was not 100% sure of the formatting, just going off ALL the other sensors I’ve ever configured)
Please feed back to provide the next guy with more info
Cheers
Thank you, I had to match the name in dashboard to make it display again, not a big problem :).
As long as it still works, you at least haven’t taken a step back.
I’m kind of intregued though, you obviously set the scan interval to give you decent battery lifetime - why do you need a plant sensor to update imediately ?
Surely the plant is not going anywhere ???
Bcause my garden is using hydroponic, and the pump is pretty strong, a minutes can make it over water, so I want when the pump is running, the sensor will update in second to cut off the pump in right time.
Okay, if you don’t get a answer to this we can still fix your problem.
What we could do is run the pump for a minimum amount of time.
Wait 5 mins, check if value still below required moisture level
Run the pump again for the mininum amout of time.
Wait 5 mins …
In fact you could run that 24 hours a day if you need moisture level to be at a minimum
This should save you water and the risk of flooding if the sensor is in a dry spot, though if it’s proper hydroponics the plants are just in a nutrient rich solution ??? (dunnoe, I’m guessing)
A possible issue with this is your pump may have a maximum number of starts an hour or similar.
Edit : though thinking about this, you ‘may’ want to turn off such an automation during certain hours (“HEY ! I’m trying to sleep here !”)
These devices broadcast their state when it changes (at least that is how it works with esphome, I assume the direct home-assistant integration works the same.)
OK I assume wrong. I would highly recommend getting an esp32 device and use esphome:
- It can access more than one miflora
- It updates when the miflora broadcasts data, which is whenever data changes, so your sensor should always be up to date.
I dont think miflora auto send broadcasts data, bcause when I change scan_interval to 1 sec, it update instantly, or when I use an app on android phone name flower care, the data update in real time. Bcause of that, I think the master device should send request to make miflora update data (there is the light on miflora flashing in time with scan_inerval), and for battery save of course.
I heared about esp32 before, it pretty cool with greater range, but in my case, I dont actually need it
