I’m trying to use the Valetudo web GUI. I managed to add zones, however I need to add segments as well. When I click the “Edit segments” in settings I’m navigated to a map and I cannot use any of the tools there except for the first one that produces a line. I can move the line around, but nothing else. When any of the tools are clicked, for each of them different error appears:
- “There can only be one split line”
- “You need to select exactly one segment to execute a split”
- “You need to select exactly two segment to execute a join”
- “You need to select exactly one segment to rename it”
Clicking over the map does nothing, I can only deselect the line.
I’m lost in this GUI. It looks like there is a bug and I’m unable to do
