Hi there! My first post jeje
Lets start, first of all i want to configure a “servo motor SG90” to go up and down at certain time. I want to create an automatiation to change the value between -100 and 100, so it moves up/down.
I just configurated the control via esphome web, but i cant control it via Home Assistant, it does not create any sensor or entity that i could modify or automate.
I will like to create a button to turn the value to -100 or 100 or something similar and usefull!
Anyone knows how can i do this?
The config:
# Example configuration entry
servo:
- id: my_servo
output: pwm_output
# Example output platform
# On ESP32, use ledc output
output:
- platform: ledc
pin: GPIO13
frequency: 50 Hz
number:
min_value: -100
initial_value: 0
max_value: 100
step: 1
optimistic: true
set_action:
then:
- servo.write:
level: !lambda 'return x / 100.0;'
Thanks for the help!
