How to add SmartThings multi-sensor with usbzb-1 stick
I have added two Osram outdoor light strips successfully, and had trouble adding two more of those. I thought I would try to add a smartthings multisensor, but don’t know how, since they don’t plug in. Do I remove and reinsert the battery, then run zha.permit? Or do I need to add a parameter when I run zha.permit?
I am on 0.81.6. Thanks!
Doing a bit of googling it looks like there is a button under the battery compartment that you have to hold down while putting the battery in to put it in paring mode.
Ugh. So simple. I should have tried harder. Thank you!
