MartinG
(Martin)
February 5, 2023, 2:54pm
1
I have a template chip cards showing some readings in particular room in one line. I want to separate this numbers with three (or more spaces), but output is always one space. I have tis code
primary: Bedroom
secondary: >-
{{ states('sensor.hue_motion_sensor_1_temperature') }} °C __ {{
states('sensor.hue_motion_sensor_1_illuminance') }} lux __ {% if
is_state('light.bedroom', 'on') %} {{ (state_attr('light.bedroom',
'brightness')/255*100)|round(0) }} % {% endif %}
I need spaces instead of underscores, how to achieve that?
How about this?
(You may also need to supress line breaks.)
primary: Bedroom
secondary: >-
{{ states('sensor.hue_motion_sensor_1_temperature') }}{{ '°C ' }}{{
states('sensor.hue_motion_sensor_1_illuminance') }}{{ 'lux '}}{% if
EdwardTFN
(Edward Firmo)
February 5, 2023, 3:20pm
3
Adding to what @templeton_nash suggested, I would prevent the case where some of those values are not available, just like you have done for brightness…
Something like this:
primary: Bedroom
secondary: >-
{% if is_number('sensor.hue_motion_sensor_1_temperature') %}
{{ states('sensor.hue_motion_sensor_1_temperature') | round(0) }}{{ '°C ' }}
{% endif %}
{% if is_number('sensor. hue_motion_sensor_1_illuminance') %}
{{ states('sensor.hue_motion_sensor_1_illuminance') | round(0) }}{{ 'lux '}}
{% if is_state('light.bedroom', 'on') %}
{{ ((state_attr('light.bedroom', 'brightness') | float(0))/255*100) | round(0) }} %
{% endif %}
MartinG
(Martin)
February 5, 2023, 3:55pm
4
Thanks.
How do I supress line breaks?
Edit: i just tried it and its still one space only
You suppress line breaks by putting a dash immediately after the opening braces and/or immediately before the closing braces.
If there is a percent sign then after the opening sign and/or before the closing sign.
Try putting the following in the developer tools → TEMPLATES
{{ 'X X' }}
and try putting extra spaces between the X’s.
MartinG
(Martin)
February 5, 2023, 4:58pm
6
Here is a screenshot of the code and output (right most template card). Despite in the code is ‘C .’ on the card there is just one space between C and dot.
I see what you mean.
My guess is that the card is passing the spaces straight into the final HTML.
In HTML one would add a non-breaking space   to get a decimate space.
I’m not sure if this is the issue or how you can insert this if it is.
Maybe someone more technical than me can help. Maybe you could raise an issue on GitHub so that the developers see it.
Just a thought. What is you add spaces like this:
Cronix
February 5, 2023, 6:39pm
9
Agree with @templeton_nash . In html, whitespace gets reduced to a single space. Like if you have 3 spaces " " it will result in a single space, unless you use the html entity for a space.
Not sure if the templating system converts white space to html entities, so you may have to do it manually in your code.
{{ '°C .' }}
For 3 spaces between °C and the period, etc.
MartinG
(Martin)
February 5, 2023, 6:53pm
10
It doesn’t work either, this is the output
Cronix
February 5, 2023, 6:57pm
11
try double quotes instead of single quotes.
pedolsky
(Pedolsky)
February 5, 2023, 7:08pm
12
You have to enable multiline support in the card options:
multiline_secondary: true
MartinG
(Martin)
February 5, 2023, 7:56pm
13
Bingo, that finally works, thank you very much.
mkanet
(MKANET)
May 21, 2023, 8:29am
14
I’m not sure if anyone is still watching this forum thread. I am trying to add tab spacing my card very similar to @MartinG … but it simply doesn’t work. What am I doing wrong?
type: custom:mushroom-template-card
secondary: >-
{{ states('sensor.process_0_exe') }} {{ ' ' }} VIRT:{{
states('sensor.process_0_res') }}M RES:{{ states('sensor.process_0_virt') }}M
Probably way too late…
use ALT+0160 to create an invisible character
