Hi !
I succesfully installed home assistant core in visual studio an it works (localhost:8123)
I wanted to add supervisor so I cloned GitHub - home-assistant/supervisor: Home Assistant Supervisor) in my workspace.
I found a task “run supervisor” but when want to run it I have the error :
Executing task in folder supervisor: supervisor_run <
zsh:1: command not found: supervisor_run
The terminal process "/usr/bin/zsh '-c', 'supervisor_run'" failed to launch (exit code: 127).
What did I not understand?
More generally, where can I find a wiki or a video to create a custom component.
Can you advise me a tutorial to develop a custom component:
I created a mediaplayer for my french stb " sfr decoder". with node red and I would like to transform it in a custom component.
