phier
(john)
March 22, 2022, 3:57pm
1
hello,
i need to apply a fix as a template
opened 08:57PM - 24 May 21 UTC
closed 03:50PM - 26 May 21 UTC
cannot fix ❌
🚨🚨🚨 STOP! STOP! STOP! 🚨🚨🚨
Before opening an issue, please read and fo… llow these steps:
1. Are you using HomeAssistant?
If yes, please open your issue at https://github.com/home-assistant/core/issues
UNLESS a developer told you to come here.
2. Check the troubleshooting section if your problem is described there:
https://zwave-js.github.io/zwavejs2mqtt/#/troubleshooting/bug_report
3. Check the changelog if your problem was already fixed recently.
https://github.com/zwave-js/zwavejs2mqtt/blob/master/CHANGELOG.md
We cannot provide support if you are not using the latest version.
4. Make sure to provide the necessary information, as described here:
If you are using HomeAssistant, this is how you do it:
Home Assistant -> settings -> Integrations -> Z-Wave JS -> Configure -> Create dump -> zip the json file and post it here.
🙏🏻🙏🏻🙏🏻 Thanks, now onto your issue:
### Version
**Checklist:**
- [x] I am **not** using HomeAssistant. **Or:** a developer has told me to come here.
- [x] I have checked the troubleshooting section and my problem is **not** described there.
- [x] I have read the changelog problem was **not** mentioned there.
Build/Run method
- [x] Docker
- [ ] PKG
- [ ] Snap package
- [ ] Manually built (git clone - yarn install - yarn run build )
zwavejs2mqtt version: 4.3.1
zwave-js version: 7.5.1
### Describe the bug
The `kWh` meter of the `NAS-WR01ZE` (https://devices.zwave-js.io/?jumpTo=0x0258:0x0200:0x1027:2.32) smart plug is reported/displayed as a negative number.
After resetting the accumulated meter values, sane positive values are reported for sometime, but at some point it flips to negative.
zwavejs2mqtt.log:
2021-05-24 20:46:26.806 DEBUG SOCKET: Event ZWAVE_API emitted to FHb1fJMDSyU3lbGJAAAB
2021-05-24 20:46:26.808 INFO ZWAVE: Calling api refreshCCValues with args: [ 42, 50, [length]: 2 ]
2021-05-24 20:46:26.971 INFO ZWAVE: Node 42: value updated: 50-0-value-65537 -21474836.13 => -21474836.13
2021-05-24 20:46:27.120 INFO ZWAVE: Node 42: value updated: 50-0-value-66049 27.85 => 27.49
2021-05-24 20:46:27.266 INFO ZWAVE: Node 42: value updated: 50-0-value-66561 234.62 => 234.93
2021-05-24 20:46:27.410 INFO ZWAVE: Node 42: value updated: 50-0-value-66817 0.25 => 0.25
zwavejs.log:
2021-05-24T20:46:26.811Z CNTRLR » [Node 042] querying meter value (type = Electric, scale = kWh, rate type = Con
sumed)...
2021-05-24T20:46:26.975Z CNTRLR » [Node 042] querying meter value (type = Electric, scale = W, rate type = Consu
med)...
2021-05-24T20:46:27.123Z CNTRLR » [Node 042] querying meter value (type = Electric, scale = V, rate type = Consu
med)...
2021-05-24T20:46:27.268Z CNTRLR » [Node 042] querying meter value (type = Electric, scale = A, rate type = Consu
med)...
The negative value also gets picked up by Home Assistant.
### To Reproduce
Let the device report for some time.
### Expected behavior
A sane number being reported.
### Additional context
*I am unsure if this is a SW issue or a quirk with the device itself, since it looks like bit 31 is being flipped.*
The screenshot below was made not too long after a reset of the accumulated values. If I take the negative number and flip bit 31 from 1 to 0, we get `35`, which would be `0.35` kWh I presume, and that would make sense given that a reset was done earlier.
This is happening on multiple of the same devices I own, not only a single one.
![image](https://user-images.githubusercontent.com/4130005/119406394-04428b00-bce3-11eb-9968-bfd0cfaab304.png)
specifically its Home Assistant Template Sensor - Shenzhen Neo NAS-WR01ZE Reported kWh Energy Correction · GitHub
but i have no idea how to do that? Do i have to create separate yaml file under config/ or do i have to add code into configuration.yaml?
thanks
Tinkerer
(aka DubhAd on GitHub)
March 22, 2022, 4:04pm
2
That can be added directly to configuration.yaml
, replacing sensor.my_device_power_electric_consumption_kwh
with your sensor entity.
Then run a command line config check:
ha core check
Before restarting HA
phier
(john)
March 22, 2022, 4:14pm
3
@Tinkerer its zwave device, its not inside configuration.yaml
petro
(Petro)
March 22, 2022, 4:22pm
4
The template is pasted into your configuration.yaml. And you replace the entity_id in the template with your zwave entity_id. That’s what tinkerer is saying.
phier
(john)
March 22, 2022, 4:24pm
5
@petro okay, i will try, there is no separate file like template.yaml or dir for that? thx
petro
(Petro)
March 22, 2022, 4:26pm
6
that depends on how you set up your system. If you don’t know, then you’ll just be putting that in configuration.yaml
phier
(john)
March 22, 2022, 4:28pm
7
but i am afraid it does not work…
i added
but i cant see / find Entity like that here >
its not even here…
phier
(john)
March 22, 2022, 4:30pm
9
well i did hm. i can do it again… but i did via ssh. reboot.
petro
(Petro)
March 22, 2022, 4:32pm
10
You don’t need to reboot, just restart home assistant. Make sure config check works.
phier
(john)
March 22, 2022, 4:33pm
11
not sure what does it mean to restart homeassistant,
but i now clicked on Restart Supervisor and its there.
But i don’t think it is working properly?
seems like pretty mess… in configuration its called
{% set value = states(‘sensor.wall_plug_switch_power_electric_consumption_kwh’) | float(‘unknown’) %}
in UI its sensor.usb_qc_charger_
petro
(Petro)
March 22, 2022, 4:36pm
12
Restart supervisor restarts the supervisor, not home assistant. You’d need to restart home assistant.
Configuration → Settings → Server Control tab → Restart
petro
(Petro)
March 22, 2022, 4:39pm
13
This creates a new entity that uses the other entity. You will have 2. It does not replace your existing entity.
phier
(john)
14
seems broken even after restart…
even configuration.yaml
phier
(john)
March 22, 2022, 4:41pm
15
it says Unknown in status… so no clue.
petro
(Petro)
March 22, 2022, 4:42pm
16
you didn’t use the correct entity_id. You’re image shows the word power
in your template, where your entity_id on the other image does not have that word.
phier
(john)
March 22, 2022, 4:43pm
18
@petro ah now i got it … see your point … i will correct. Appreciate your help.
petro
(Petro)
March 22, 2022, 4:48pm
19
I suggest you move to some other type of editing. Via SSH is a pita. You can setup samba share to access the files from another machine or use the Visual Studio Code addon.
