How to add this button press as trigger?
Im using home assistant with Deconz. One of the devices I want to use for an automation is a heiman hs1rc-ef keyfob. The device is visible in HA, but the buttons are not configured. However, When I go to developer option and listen for events, I can see the events like this:
“event_type”: “deconz_event”,
“data”: {
“id”: “rc_ef_3_0_142”,
“unique_id”: “ec:1b:bd:ff:fe:0f:a7:7d”,
“event”: 1002,
“device_id”: “73037549fd4840747f976d22cc21dafe”
“origin”: “LOCAL”,
“time_fired”: “2021-04-19T20:30:06.498267+00:00”,
“context”: {
“id”: “754eb1fcb34cd0f67af481118a6e4571”,
“parent_id”: null,
“user_id”: null
I want to know how I can use this imput as a trigger for an automation… Do I have to copy this info to a config file in order to use it as a trigger?
Your automation can use an Event Trigger.
For example (change the action to whatever you want):
- alias: 'Example 1'
  - platform: event
    event_type: deconz_event
    event_data:
      event: 1002
  - service: notify.persistent_notification
      title: Heiman Keyfob
      message: Button event 1002
EDIT
Correction. Forgot to include the trigger: option!
Hi, thanks for your help… I tried some stuff, but still cannot get it done…
When I totally copy and pasta your code into automations.yaml, i am getting an error:
bad indentation of a sequence entry at line 2, column 3:
- platform: event
I tried t modify it a bit myself,but nothing change. I also tried some other code like this: Wich is not working aswell:
  • id: ‘1618899828547’
    alias: Nieuwe automatisering
    description: ‘’
    • platform: event
      event_type: ‘’
      event_data:
      event_data:
      event: 1002
      condition: []
    • type: toggle
      device_id: 50a7afac89eb111c5206e3169961858d
      entity_id: light.spot_midden
      domain: light
      mode: single
I made this with the automation plugin. But again, not working… What is going wrong?
My apologies, I made a silly mistake and failed to include the trigger: option!
I have corrected the example posted above. Here is a version that toggles a light.
  - platform: event
    event_data:
      event: 1002
  - service: light.toggle
Aaaaaah thanks! It is working! That is a nice start to do some other stuf with it.
One problem: When I press the button once, it repeats the signal 3 or 4 times… So in the action part, I use switch a light to on or of, it goes on, off, on, off, on, off… Any suggestions?
That’s a separate issue and is due to ‘contact bounce’ caused by the physical button’s operation.
The usual “debouncing” technique is based on timing. You define a minimum time period between button presses such as 2 seconds and ignore all events that occur faster than 2 seconds.
For example, imagine after the first 1002 is received, more are generated every 0.25 seconds. We would ignore events 2 through 8 because they were all received within 2 seconds of the first one. We would accept only the one that arrives 2 (or more) seconds after the first one.
0.0 --- 0.25 --- 0.5 --- 0.75 --- 1.0 --- 1.25 --- 1.5 --- 1.75 --- 2.0
 1       2        3       4        5       6        7       8        9
YES------NO-------NO------NO-------NO------NO-------NO------NO------YES
The challenge is where to get the timing information? I would suggest using the automation’s own last_changed time but a fair bit of experimentation is needed to arrive at a working solution.
Another way to debounce it is to use a proxy such as an input_boolean
  • When the first 1002 is received, it turns on an input_boolean.
  • When additional 1002 events are received, each one also turns on the same input_boolean. However, the first time the input_boolean is turned on, additional attempts to turn it on effectively do nothing (the input_boolean has effectively debounced the stream of 1002 events).
Create the following input_boolean:
input_boolean.spot_midden
then try this automation:
  mode: queued
  - platform: event
    event_data:
      event: 1002
  - platform: state
    entity_id: input_boolean.spot_midden
    to: 'on'
  - platform: state
    to: 'on'
    for: '00:00:02'
  - choose:
    - conditions: "{{ trigger.platform == 'event' and is_state('input_boolean.spot_midden', 'off') }}"
    - conditions: "{{ trigger.for is defined and trigger.for != None }}"
      sequence:
      - service: input_boolean.turn_off
    default:
How it works:
  • When triggered by the first 1002 event, it turns on input_boolean.spot_midden. Any additional 1002 events received within 2 seconds will be ignored because the input_boolean’s state is already on.
  • When input_boolean.spot_midden turns on, it triggers the same automation which proceeds to toggle light.spot_midden.
  • After input_boolean.spot_midden is on for 2 seconds, the automation forces it back to off. Now it is ready to receive new 1002 events.
Thanks for this detailed information A LOT!! I will give it a try.
Only one thing to mention: When I listen to events under developer tools, and I press the button, only 1 event is registrated. Because the event runs multiple times, can there also be another reason for this behavior?
These are contradictory observations; I have no idea which one is actually happening.
Haha, I’m sorry. That is a bit confusing indeed!
The last one is thrue! With the first one I mean: The action is triggered 3 or 4 times… And I have no idea why that is…
The last part I figured out later… I thought, Let’s take a lot there to see how many events are received. And that is just one…
EDIT: Sorry sorry sorry, the event itself is also received multiple times. But there is some delay. So I will try your solution.
