I’d like to add the time to the tops of my dashboard like this:
I also for the life of me cannot get rid of that space under the media player. I must have futzed with this for hours to no avail. What’s the trick?
Haven’t tried it, but there’s a HACS card called Lovelace Header Cards. One of their examples is a clock.
Have you looked at vertical and horizontal stacks to get rid of the space?
This is a sidebar layout (the sidebar is on the right). The section on the left is made up of two horizontal stacks - the top one contains four vertical stacks of cards; the bottom one is just two cards. (The reminders card needs space underneath it because it expands if there are more entries.)
@jackjourneyman Brilliant. I’ve used Vertical stacks all over the place, but didn’t think of using them in the section type layout as I figured there would have to be some type of layout control there. Wishful thinking.
There’s a HACS version called Vertical Stack In which doesn’t leave gaps between the cards:
