How to add 'unique_id' to templates
I’m trying to setup a series of simple entities that reflect the direction/vector across any two motion sensors, and from there build some clever automations that watch those entities.
I have a template with two test sensors working, but I can’t seem to get the “unique_id” property to reflect in HA’s interface.
The below just gives me an entity named “sensor.test_a”:
- unique_id: asdf
- sensor:
    state: >
      {{ is_state("binary_sensor.roomA_sensor_motion", "on") and
         is_state("binary_sensor.roomB_sensor_motion", "on") }}
I’ve also tried this (to no avail):
- sensor:
    unique_id: asdf
    state: >
Any help would be appreciated.
nm, somehow I got it working. For future reference:
  • i removed the ‘name’ field and just left ‘unique_id’ in place that half-worked
  • then i replaced the name field (above unique_id this time, not sure it matters), and now it shows up correctly
Could be that the entity had to be created first, and then renamed in the template?
You can create an unique_id immediately:
    - name: "House electricity energy"
      unique_id: '0a7476cc-d6c1-40ba-8ae1-606518c3497f'
      unit_of_measurement: 'kWh'
      state: >
        {{ ((states("sensor.mains_consumed_energy") | float(0)) + (states("sensor.upstairs_consumed_energy") | float(0)) + (states("sensor.extra_consumed_energy") | float(0)) )| round(2) }}
      availability: >
        {{ not 'unavailable' in
        [ states('sensor.mains_consumed_energy'),
          states('sensor.upstairs_consumed_energy'),
          states('sensor.extra_consumed_energy') ] }}
      device_class: energy
      state_class: total_increasing
I know this is an old topic but how does this create a unique id immediately? Can I just create a unique_id option and leave it blank for HA to update/generate a unique id? Or do I just type in a bunch a characters?
I’m having a few trigger template sensors provided via yaml and would like to manage them inside HA.
I just generate them using an online unique id generator
I use StudioCodeSever as editor. in the past, when editing a yaml file, you could call the conext menu (right mouse button) and there was a command: “generate UUID at cursor position”. After a recent update of StudioCodeServer this option disappeared. does enyone know why?
Make sure the vscode extension is installed. In vscode click the extensions tab and see what’s installed
