I have installed and worked with Home Assistant on a raspberry pi for few days now. Just added some aqara zigbee devices via Zigbee2MQTT (fw 1.17.1) addon and all is working well, but the power plug is missing the voltage entity (I can see the voltage so the power plug is sending the info but it was not added as an separate entity).
Is there any way to manually add an entity to this device ?
Something like “sensor.0x00131d0001a16fb2_voltage”, “voltage”
Some info from device:
Zigbee model lumi.plug
Description Mi power plug ZigBee
Support status Supported
Firmware build date 02-28-2017
Vendor Xiaomi
Model ZNCZ02LM
Power source Battery
Interview completed Yes
Thank you.
