jsalas
(jsalas)
1
I have a zigbee ( zigbee2mqtt) device hat exposes these values:
"child_lock": "UNLOCK",
"current": 9.01,
"energy": 1203.98,
"indicator_mode": "off",
"linkquality": 76,
"power": 1972,
"power_outage_memory": "on",
"state": "ON",
"voltage": 223,
"update": {
"installed_version": -1,
"latest_version": -1,
"state": null
"update_available": null
When I go to the entities, I only see these values and none of those relates to the current:
![image](https://community-assets.home-assistant.io/original/4X/7/e/3/7e3b4ef618abb54ac650a220e2b1e4a980a71a56.png)
How can I display the current ( amperes ) in the main dashboard if i see no entity related to that?
Tinkerer
(aka DubhAd on GitHub)
2
That’ll probably be the attribute of one of those, check https://my.home-assistant.io/redirect/developer_states/
jsalas
(jsalas)
3
@Tinkerer that link is broken.
Tinkerer
4
Works here, and for everybody with the my
integration (which is part of default_config
Since you disabled it you’ll have to select States from Developer Tools.
francisp
(Francis)
5
Go to the device, see if current is not a hidden sensor.
jsalas
(jsalas)
6
I dont see anything related to current.
jsalas
(jsalas)
7
inside the zigbee2mqtt ?
I see this:
