How to add zwave/zigbee USB to hassio docker
There’s a previous thread on this topic, but it’s 2 years old, so maybe things have changed.
Following the instructions on this page, it works well -all the docker containers are up and running. And the installer “Requirements” notes page does say that " Access USB devices: done by the installer". This part I’m not sure about. When I look at the System>Host Hardware Info in HA, it does pickup on the USB zwave/zigbee stick along with the correct paths, but it doesn’t show up in HA as a device or integration like it does with just the HA-Core docker image.
This page does say to modify the configuration.yaml file to add zwave (and similarly zigbee) which I did do:
# Example configuration.yaml entry
zwave:
  usb_path: /dev/ttyUSB0
  device_config: !include zwave_device_config.yaml
But when I verify the config, it doesn’t like the config file path.
I’m missing something. I think the best thing to do would be just to edit the ‘docker run’ file for the hassio installation and add the devices with the below two lines - but I don’t see a way to do that from within the script linked above.
--device=/dev/ttyUSB0 \
--device=/dev/ttyUSB1 \
Maybe this is a dead-end, maybe I just stick to HA-Core with no supervisor and no add-on panels, but that does seem like it would make things much easier to administer HA.
As usual, time will heal all wounds and solve problems…sometimes. Replying here in case someone else runs into similar problems.
I figured out that since HA was seeing the /dev devices in the Hardware info screen, it was just a matter of adding the zwave and ZHA controllers in integrations.
I am so pleased to get this working - it’s been a struggle the past couple days trying to migrate from the silo of HA-Core container, but I am finally at peace to have supervisor and add-ons working now. Now to get busy moving things over from ST.
And if anyone who has a GoControl CECOMINOD016164 HUSBZB-1 USB Hub wonders about the mappings on Ubuntu 18 - it’s:
zwave:
zha:
  usb_path: /dev/ttyUSB1
But you realize those paths can change right?
Thsts why its best to add the devices by-id or by setting up a persistent path in a udev rule. That way no matter what the “real” device path is it will always be seen correctly by HA.
