How to address data gaps in MQTT sensors and force to always show a value?
I have a number of Lorawan sensors connected to HA via MQTT. Some of these report perfectly and always show a value. Others have gaps in reporting, as per the image below. I would like these ‘gappy’ sensors always to show the last-received value.
soilmoisture
I think what is happening is that I have multiple sensors using the same MQTT state topic, and so when a second sensor reports via MQTT and that message doesn’t contain a json value that the first sensor is looking for, the first sensor switches to an ‘unknown’ value. Unfortunately, I think the act that they share a topic means that simply retaining MQTT messages may not be the answer.
Switching sensors to binary_sensor has solved the problem in some cases. But for sensors such as the soil moisture probe shown here, that’s clearly not an option.
What’s a simple way to force the dashboard to show the last value?
Wrong question: the dashboard should show the current value, but you can either change the entity it’s showing, or change how the current entity is configured.
Are these auto-discovered sensors or have you configured them?
Easiest way might be to configure a template sensor helper for each troublesome sensor, with a state template like:
{{ states('sensor.soilmoisture')|float(this.state) }}
That tries to convert the state of the soilmoisture sensor to a number, and returns the existing value of this sensor if it fails. Then show that “retained soil moisture” template sensor in the dashboard.
Thanks. The sensors were all added manually, not auto-discovered. I’ll try the template sensor helper as you suggest and report back.
In that case, you can do the “retaining” directly in the MQTT config. Post the YAML for one of them (correctly formatted please) and I’ll have a go.
Here’s my entry for the soil moisture sensor above. The reason for looking for the dev_eui was in order to distinguish this from another which has the same mqtt topic. (I realise that’s probably daft and that I should filter the topics differently, but for a few reasons it’s less straightforward to change the mqtt broker).
    - name: "soilmoisture"
      unique_id: lorawan_soilmoisture1
      state_topic: "homeassistant/sensor/lorawan/water"
      unit_of_measurement: "%"
      icon: mdi:water-percent
      value_template: >-
        {% set dev_eui = value_json.end_device_ids.dev_eui %}
        {% set moisture = value_json.uplink_message.decoded_payload.soilmoisture %}
        {% if dev_eui == "REDACTED" %}
          {{ moisture }}
        {% else %}
        {% endif %}
(This is one of a number of sensors under mqtt / sensor, hence missing that part of the YAML)
      value_template: >-
        {% set dev_eui = value_json['end_device_ids']['dev_eui'] %}
          {{ value_json['uplink_message']['decoded_payload']['soilmoisture'] }}
        {% else %}
          {{ this.state }}
        {% endif %}
Using the always-better bracket notation, and moving the moisture lookup after we know you have the right device.
This assumes your REDACTED device always sends valid data, and the problematic missing data is from the other device.
Unfortunately this now generates an error:
Validation error: Invalid config for ‘sensor’ at configuration.yaml, line 143: invalid template (TemplateSyntaxError: unexpected ‘}’, expected ‘]’) for dictionary value ‘value_template’, got ‘{% set dev_eui = value_json['end_device_ids']['dev_eui'] %} {% if dev_eui == “REDACTED” %}\n {{ value_json['uplink_message']['decoded_payload']['soilmoisture]' }}\n{% else %}\n {{ this.state }}\n{% endif %}’, please check the docs at MQTT - Home Assistant
Heh, always better unless mistyped. Swap the quote and bracket after soilmoisture, fixed in my post above. Sorry.
Brilliant - seems to be working now and presents as a continuous variable in the dashboard. Will change the other misbehaving sensors similarly. Much appreciate your assistance!
