How to adjust brightness on a Shelly Plus Wall Dimmer switch with MQTT
Hi All,
I need your help. I am pretty much a novice with Node Red, HA, and MQTT. However, I have set up several flows to turn on and off lights based on motion and door sensors. I am using HA, Node Red, and Mosquitto in a Docker container. I have used MQTT Explored, and I am able to see messages, and I also know that in the data object there is an attribute brightness or brightness_pct. I’ve read the Shelly documentation which gets me no where.I’ve looked on this forum. I’ve looked at various YouTubes with some help. I have used the MQTT in and out nodes for subscribe and publish. I just don’t understand the Shelly API documentation.
It’s something like ShellyId/events/rpc/command, but after that I’m stuck.
TIA,
Steve
I did this once before I was using HASS when I was trying to get the wall dimmer into HomeKit. It worked well but I have since moved on and no longer use node red.
I went back to an email exchange with someone at the time and I have included my complete flow that I came up with. I hope it helps you get on track.
       "id": "f86e55ab0740a4ba",
       "type": "mqtt out",
       "z": "400bc6822dea397a",
       "name": "MQTT Control",
       "topic": "GreenRoom/rpc",
       "qos": "1",
       "retain": "",
       "respTopic": "",
       "contentType": "",
       "userProps": "",
       "correl": "",
       "expiry": "",
       "broker": "4981d51eace3b4be",
       "x": 500,
       "y": 280,
       "wires": []
       "id": "ba3a7e4559ae2a7b",
       "type": "mqtt in",
       "name": "MQTT Status",
       "topic": "GreenRoom/status/light:0",
       "qos": "1",
       "datatype": "auto-detect",
       "nl": false,
       "rap": true,
       "rh": 0,
       "inputs": 0,
       "x": 90,
       "y": 100,
       "wires": [
               "012f353a0b44ce6c"
       "id": "0b0e4e10c1c5cd86",
       "type": "function",
       "name": "translate",
       "func": "if (msg.payload.output == true) {\n    msg.payload = {\"On\": 1, \"Brightness\": msg.payload.brightness};\n   return msg;\n} else {\n    msg.payload = {\"On\": 0, \"Brightness\": msg.payload.brightness};\n    return msg;\n}",
       "outputs": 1,
       "noerr": 0,
       "initialize": "",
       "finalize": "",
       "libs": [],
       "x": 400,
       "y": 100,
       "wires": [
               "d858da0bef12c43c"
       "id": "c4b46c5de05d51c4",
       "type": "homekit-service",
       "isParent": true,
       "hostType": "0",
       "bridge": "89283e495d5d1ab0",
       "accessoryId": "",
       "parentService": "",
       "name": "GreenRoom",
       "serviceName": "Lightbulb",
       "topic": "",
       "filter": false,
       "manufacturer": "NRCHKB",
       "model": "1.4.3",
       "serialNo": "Default Serial Number",
       "firmwareRev": "1.4.3",
       "hardwareRev": "1.4.3",
       "softwareRev": "1.4.3",
       "cameraConfigVideoProcessor": "ffmpeg",
       "cameraConfigSource": "",
       "cameraConfigStillImageSource": "",
       "cameraConfigMaxStreams": 2,
       "cameraConfigMaxWidth": 1280,
       "cameraConfigMaxHeight": 720,
       "cameraConfigMaxFPS": 10,
       "cameraConfigMaxBitrate": 300,
       "cameraConfigVideoCodec": "libx264",
       "cameraConfigAudioCodec": "libfdk_aac",
       "cameraConfigAudio": false,
       "cameraConfigPacketSize": 1316,
       "cameraConfigVerticalFlip": false,
       "cameraConfigHorizontalFlip": false,
       "cameraConfigMapVideo": "0:0",
       "cameraConfigMapAudio": "0:1",
       "cameraConfigVideoFilter": "scale=1280:720",
       "cameraConfigAdditionalCommandLine": "-tune zerolatency",
       "cameraConfigDebug": false,
       "cameraConfigSnapshotOutput": "disabled",
       "cameraConfigInterfaceName": "",
       "characteristicProperties": "{\"Brightness\": true}",
       "waitForSetupMsg": false,
       "outputs": 2,
       "x": 110,
       "y": 220,
       "wires": [
               "580049e4bb115080",
               "411416eafaf3dafd"
       "id": "1c6fa6c19c2d8660",
       "type": "function",
       "name": "build MQTT string",
       "func": "var light = flow.get(\"gr_on\");\nvar brightness = flow.get(\"gr_brightness\");\nmsg.payload = { \"id\": 123, \"src\": \"node_red\", \"method\": \"Light.Set\", \"params\": { \"id\": 0, \"on\": light, \"brightness\": brightness } };\nreturn msg;",
       "outputs": 1,
       "noerr": 0,
       "initialize": "",
       "finalize": "",
       "libs": [],
       "x": 150,
       "y": 280,
       "wires": [
               "9c7c2d1e2af175ef"
       "id": "012f353a0b44ce6c",
       "type": "change",
       "name": "Set.Env.Vars",
       "rules": [
               "t": "set",
               "p": "gr_on",
               "pt": "flow",
               "to": "payload.output",
               "tot": "msg"
               "t": "set",
               "p": "gr_brightness",
               "pt": "flow",
               "to": "payload.brightness",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 250,
       "y": 100,
       "wires": [
               "0b0e4e10c1c5cd86"
       "id": "580049e4bb115080",
       "type": "switch",
       "name": "block undefined",
       "property": "payload.On",
       "propertyType": "msg",
       "rules": [
               "t": "nnull"
       "checkall": "true",
       "repair": false,
       "outputs": 1,
       "x": 280,
       "y": 200,
       "wires": [
               "bb3975d068e4e39c"
       "id": "bb3975d068e4e39c",
       "type": "change",
       "name": "Set.Env.On",
       "rules": [
               "t": "set",
               "p": "gr_on",
               "pt": "flow",
               "to": "payload.On",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 450,
       "y": 200,
       "wires": [
               "1c6fa6c19c2d8660"
       "id": "411416eafaf3dafd",
       "type": "switch",
       "property": "payload.Brightness",
       "rules": [
               "t": "nnull"
       "checkall": "true",
       "repair": false,
       "outputs": 1,
       "x": 280,
       "y": 240,
       "wires": [
               "6b722e53e8a8cc03"
       "id": "6b722e53e8a8cc03",
       "type": "change",
       "name": "Set.Env.Brightness",
       "rules": [
               "t": "set",
               "pt": "flow",
               "to": "payload.Brightness",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 470,
       "y": 240,
       "wires": [
               "1c6fa6c19c2d8660"
       "id": "d858da0bef12c43c",
       "type": "rbe",
       "name": "limit dupes",
       "func": "rbe",
       "gap": "",
       "start": "",
       "inout": "out",
       "septopics": false,
       "property": "payload",
       "topi": "topic",
       "x": 550,
       "y": 100,
       "wires": [
               "c4b46c5de05d51c4"
       "id": "9c7c2d1e2af175ef",
       "type": "rbe",
       "func": "rbe",
       "gap": "",
       "start": "",
       "inout": "out",
       "septopics": false,
       "topi": "topic",
       "x": 330,
       "y": 280,
       "wires": [
               "f86e55ab0740a4ba"
       "id": "5368d2bf9b9b7119",
       "type": "comment",
       "name": "MQTT Status sets NR HomeKit Object to current device state.",
       "info": "",
       "x": 240,
       "y": 60,
       "wires": []
       "id": "2d5105027c3c5d34",
       "type": "comment",
       "name": "NR HomeKit Object sets device state via MQTT",
       "info": "",
       "x": 200,
       "y": 160,
       "wires": []
       "id": "cb8830c759c56ef7",
       "type": "comment",
       "name": "Flow Environment variables hold current or target state between MQTT messages",
       "info": "",
       "x": 300,
       "y": 20,
       "wires": []
       "id": "4981d51eace3b4be",
       "type": "mqtt-broker",
       "name": "Mosquitto",
       "broker": “192.168.1.xx",
       "port": "1883",
       "clientid": "",
       "autoConnect": true,
       "usetls": false,
       "protocolVersion": "5",
       "keepalive": "60",
       "cleansession": true,
       "birthTopic": "",
       "birthQos": "0",
       "birthRetain": "false",
       "birthPayload": "",
       "birthMsg": {},
       "closeTopic": "",
       "closeQos": "0",
       "closeRetain": "false",
       "closePayload": "",
       "closeMsg": {},
       "willTopic": "",
       "willQos": "0",
       "willRetain": "false",
       "willPayload": "",
       "willMsg": {},
       "userProps": "",
       "sessionExpiry": ""
       "id": "89283e495d5d1ab0",
       "type": "homekit-bridge",
       "bridgeName": "Green Room",
       "pinCode": "989-17-441",
       "port": "",
       "advertiser": "bonjour-hap",
       "allowInsecureRequest": false,
       "model": "1.4.3",
       "customMdnsConfig": false,
       "mdnsMulticast": true,
       "mdnsInterface": "",
       "mdnsPort": "",
       "mdnsIp": "",
       "mdnsTtl": "",
       "mdnsLoopback": true,
       "mdnsReuseAddr": true,
       "allowMessagePassthrough": true
