Hey,
i just bought and integrated my first Aqara P1 motion sensor after my Philips stopped working.
I am using Home Assistant Yellow with ZHA. Pairing worked, but the Sensor stays occupied for a long time. I think its the sensitivity of the sensor, but i have not found a way to adjust it. I did find some guides how to adjust the sensitivity of the Vibration Sensors via Zigbee Cluster Attributes/Commands, but i am not sure how and what to set with the motion sensor.
Has anyone been able to adjust the sensitivity with ZHA and the Aqara P1?
In the zha config for the sensor there are configuration options for the sensitivity and the detection interval.
To make the changes permanent you should first press the rest button once on the device, then make the changes. Otherwise they will return to the previous values unchanged.
