Thanks for posting your experience. That is very useful indeed! I was just going to ask if anyone already has managed to smoothly transition to the first-party integration.
Just installed the integration. However, the custum component integration by solarladen has two additional controls which I like. One is the ability to turn the inverter on/off and the second one allows to control the output-power of the inverter.
Would be nice, if those two controls are integrated in the integration in the next release.
I just installed my EZ1 with the offical HA integration and have the same problem as WebSpyder. Unfortunately no controls for the output power are shown.
There are only 9 Entities showing the power and energy status.
I am missing:
The first version of the official APsystems integration was introduced with 2024.6. It seems that the extensions didnāt make it into the latest Home Assistant minor update. Presumably the change/extension will then come with Home Assistant 2024.7 Just keep an eye on the changelogs of the latest releases Releases Ā· home-assistant/core Ā· GitHub
And yes, you can stay with the custom Integration in the meantime, till the official integration has all the features.
Let me ask you a question. I was just wondering if anyone else has the problem that the inverter goes offline every few weeks and is not accessible via API for 1-2 days.
However, if you measure the power production at the plug, you can see that the inverter is actually online and producing power correctly.
Does anyone else have this problem or know what it could be?
I have the inverter integrated locally since the beginning of the month and have so far not had that problem. Occasionally polling will fail, but it always recovers after a couple of tries.
Thank you very much for your feedback.
I will continue to monitor this. This behaviour occurs for me every 2-3 months.
In the attached screenshot you can see quite clearly that the data acquisition of the inverter (yellow) still works as usual on 22 June, then on 23 June the inverter is only accessible for one hour and then again from 24 June at 09:00.
However, the balcony power station produces electricity throughout this time, as you can see from the meterās feed-back (purple).
It is also not a display bug of the Energy Dashboard, as even a manual query of the API does not provide any data. The inverter is also not connected to the WLAN during this time and is displayed as disconnected in the router. It may also be a problem in connection with my WLAN, although I canāt think of any good reason why this should be the case and the problem only occurs every few months for 1-2 days :-/
So youāve already said it: Itās not a problem with the integration. You should test if the bluetooth connection still works when the wifi does not. If thatās not the case, try contacting APsystems.
Yes, of course. Sorry if that came across wrong. I realised from the start that there was no problem with the integration.
I was just interested to know whether this problem still generally occurs for other users. At the moment Iām blaming it on some WLAN Foo, although the coverage at the inverter point is actually quite good.
I canāt really test this with Bluetooth at the moment as I have deactivated Bluetooth in the settings.
