How to arm/disarm several alarm_control_panel at the same time?
I have a Paradox EVO192 system and I have three zones to arm/disarm. So, I have three panels alarm_control_panel.1, alarm_control_panel.2 and alarm_control_panel.3. All of them have ‘code_arm_required: false’, ‘code_disarm_required: true’ and they have the same ‘code: 1234’. So, the question is. How can I arm/disarm all of them at the same time and I want to arm them without code entering and disarm only with code entering?
Just make three service call, one for each alarm_control_panel.
Can you show your automation code?
I started writing an automation that would trigger on any 1 of the 3 being disarmed then disarm them all as the action, which would trigger the automation again (at least once). Which I thought was a bit messy. I’m still thinking about a way to select all the alarm entities except the trigger_to entity id. I could do it with a service template I suppose.
Automation does not work here, because there is no possibility to enter code to disarm zones.
I can disarm an alarm control panel with a code, should be something like this:
  service: alarm_control_panel.alarm_disarm
  entity_id: alalm_control_panel.alarm_1
    code: 1234
Yeah there is.
- service: alarm_control_panel.alarm_disarm
    entity_id: alarm_control_panel.1
    code: 1234
EDIT: too slow!
Guys, you are right, but this automation works only if you want to arm/disarm without ENTERING CODE. My idea is to make alarm_control_panel which can arm/disarm several zones.
No it doesn’t.
Trigger: Detect that one zone is disarmed (by the keypad or whatever), Action: disarm the others automatically.
In it’s simplest for it would look like this:
alias: all_alarms_off
  platform: state
  entity_id:
    - alarm_control_panel.1 # any one of these three going disarmed will trigger it
    - alarm_control_panel.2
    - alarm_control_panel.3
  to: 'disarmed'
    code: 1234
    entity_id: alarm_control_panel.2
    code: 1234
    entity_id: alarm_control_panel.3
    code: 1234
Now, the actions do have some issues. Say you disarm alarm 1, when alarm 2 and 3 are disarmed by the automation it will retrigger the automation. There is an easy and inelgant way around this:
Write this automation:
  platform: state
  entity_id:
  to: 'disarmed'
- service: script.all_alarms_off
And this script:
all_alarms_off:
  sequence:
  - service: homeassistant.turn_off # to prevent retriggering the automation
    entity_id: automation.all_alarms_off
      code: 1234
      code: 1234
      code: 1234
  - service: homeassistant.turn_on # don't forget to re-enable the automation
There are more complicated and elegant ways of selecting just the two alarms that didn’t trigger the automation using templates and selectattr(). But I prefer offering something you can understand.
My project is:
I have made an entrance wall panel witch is running on raspberry pi 4 with 7” touchscreen in kiosk mode. I want to come home and to enter only one alarm_control_panel to disarm all zones. Now I should disarm each zone separately. I have a button for each alarm panel witch calls popup window with alarm_control_panel (it has a keypad, because I use touchscreen). So I want to make something like that, that can arm/disarm several zones at the same time.
See my edit above. It does what you want.
Thank’s I will try it now
This way is not good for me too. Now there is problem with popup card, ‘deviceID: this’ for popup card doesn’t work, card is opening on all devices!
This is my code for glance card with popup alarm_control_panel:
entities:
  - entity: alarm_control_panel.perimetr_s_kodom
    name: Периметр и гараж
    styles:
      card:
        - animation: |
              if (states['alarm_control_panel.perimetr_s_kodom'].state == 'pending') return 'blink 2s ease infinite';
               else return 'null';
      icon:
        - color: |
              if (states['alarm_control_panel.perimetr_s_kodom'].state == 'armed_away') return 'red';
              if (states['alarm_control_panel.perimetr_s_kodom'].state == 'disarmed') return 'green';
              else return 'orange';
    tap_action:
      action: call-service
      service: browser_mod.popup
      service_data:
        card:
          states:
            - arm_away
          type: alarm-panel
        deviceID:
          - this
        large: false
        title: Клавиатура
style: |
  ha-card {
    color: black;
    font-size: 12px;
    font-weight: bold;
  .card-header {
    font-size: 23px;
    color: black;
    text-align: center;
type: glance
I don’t know what you mean. Adding a script and an automation won’t change the way your front end works.
Wait, are you talking about something completely different now?
Did the automation and script work?
It works, but not the way I want. I have three zones and I want to arm/disarm them in different combinations. Separately, by two or all together. For example: to leave garage armed, and to disarm two rest zones. The idea of my project is that I have buttons on the screen, witch call popup card with alarm_panel. There is now any problem with arming zones, because I can use Template Alarm Control Panel (it doesn’t use code). To disarm without code I can use Template Alarm Control Panel too. But, I need to use CODE!!! for arming, and here I have problems … Template Alarm Control Panel doesn’t support code, if I use script for tap_action I have incorrect work of popup card and …
The appearance of my panel on raspberry pi in kiosk mode:
when I push glance card for one zone I have popup card like this:
So I want to have the same popup card to disarm several zones.
That is not what you asked for originally:
It helps to be very clear with your question. Otherwise you are just wasting your time and mine.
You are going to have to design a custom card to do what you want. You can’t do it with the existing alarm panel card. You could probably emulate it with the custom-button-card.
It is very good idea to make a custom alarm card, but I am far from doing it. That’s why I asked the question, may be somebody already solved this problem. It seems to me that it would be a very useful card.
Here is the solution without creating custom card. Thanks to @tom_l he gave mi the way to go. May be someone will use it.
Alarm panels I use:
- platform: mqtt
  state_topic: 'manual/perimetr_garagh/alarm'
  command_topic: 'alarm/perimetr/garazh' # this is a fake command_topic to use it with automations
  payload_disarm: 'disarm'
  payload_arm_away: 'arm'
  code: 12345
- platform: manual_mqtt
  name: "Manual Perimetr Garagh"
  command_topic: 'manual/perimetr_garagh/alarm'
  armed_away:
    pending_time: 0
    delay_time: 0
  state_topic: 'manual/test1/alarm'
  command_topic: 'manual/test1/alarm/set'
  armed_away:
    pending_time: 0
    delay_time: 0
  state_topic: 'manual/test2/alarm'
  command_topic: 'manual/test2/alarm/set'
  armed_away:
    pending_time: 0
    delay_time: 0
alarm_control_panel.manual_perimetr_garagh is created to use it’s state_topic for alarm_control_panel.main_panel
Automations I use:
- alias: 'alarm_perimetr_garazh_arm'
  initial_state: 'on'
    platform: mqtt
    topic: alarm/perimetr/garazh
    payload: 'arm'
  - service: alarm_control_panel.alarm_arm_away
      entity_id: alarm_control_panel.manual_test1
      entity_id: alarm_control_panel.manual_test2
- alias: 'alarm_perimetr_garazh_disarm'
  initial_state: 'on'
    platform: mqtt
    payload: 'disarm'
- alias: 'alarm_alarm_perimetr_garagh_state1'
  initial_state: 'on'
    platform: homeassistant
    event: start
  condition:
    condition: or
    conditions:
      - condition: state
        state: 'armed_away'
      - condition: state
        state: 'armed_away'
      entity_id: alarm_control_panel.manual_perimetr_garagh
- alias: 'alarm_alarm_perimetr_garagh_state2'
  initial_state: 'on'
    event: start
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'disarmed'
      - condition: state
        state: 'disarmed'
- alias: 'alarm_alarm_perimetr_garagh_state3'
  initial_state: 'on'
    platform: state
    entity_id:
      - alarm_control_panel.manual_test1
      - alarm_control_panel.manual_test2
    to: 'armed_away'
- alias: 'alarm_alarm_perimetr_garagh_state4'
  initial_state: 'on'
    platform: state
    entity_id:
    to: 'disarmed'
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'disarmed'
      - condition: state
        state: 'disarmed'
