Hi all, at the moment i’m running hass 110.3 but i would like to run 106.6 as it’s running on a rasp zero w and i’m trying to build a door bell. Is there a way to auto start the previous version. Here is my service file.
[Unit]
Description=Home Assistant
After=network.target
[Service]
Type=simple
User=pi
ExecStart=/usr/local/bin/hass
[Install]
WantedBy=multi-user.target
tom_l
July 10, 2020, 1:54pm
2
You can install a previous version from the home assistant CLI:
ha core update --version=x.y.z
Be wary of any breaking changes you have rectified as they will have to be reverted.
How do i update the core using raspbian? as i’ve tried pip3 install ha core update --version=0.106.6 but that does not work.
tom_l
July 13, 2020, 9:04am
4
You did not mention you were running the core version. That does not have the home assistant CLI. Try this instead:
pip3 install homeassistant==0.XX.X
Yeah done that but its still showing version 0.112.0 do you know how i can activate the newly downloaded version?
